Stuck governor cone
this thread has 3 replies and has been viewed 1534 times
Old 01-09-2002, 11:13:01 PM
Brian
Default Stuck governor cone
Hi all,
I have a 2hp Witte headless engine. It would be ready to run aside from the buzz coil needing to be set up, but the governor cone is rusted to the crankshaft and I haven't been able to free it up. Tried wd-40, pipe wrench, etc. and nothing makes it budge. It's a little frustrating especially since the engine turns over great and has strong compression (hard to turn over!). Can anyone offer some advice on how to get the governor cone free?
Thanks a lot, Brian
Old 01-09-2002, 11:19:07 PM
glenn
Default Re: Stuck governor cone
Heat and tap on it.
Old 01-10-2002, 01:26:06 AM
D Baalman
Brian have to agree on the heat and taping on it. WD40 is next to worthless as a penetrant. It does lubricate but evaporates too quick to penetrate any. Use PB blaster available @ Walmart. Good luck and PATIENCE are a must. Dan
Old 01-10-2002, 07:25:28 AM
NICK
Don't try and twist it! There is a pin in the flywheel that goes into a hole in gov sleeve to keep it from rotating. Try careful heat and PB Blaster along with a brass hammer, combination works wonders!
NICK
Cone Head Rivets? dbyam Steam Stationary Engines, Traction Engines, Steam Boats 53 11-04-2013 10:53:20 PM
Blacksmith's cast iron cone? darrelld Blacksmithing and Metallurgy 2 12-24-2007 10:42:15 AM
Oil Governor/Steam Governor Ed Bertschy Steam Stationary Engines, Traction Engines, Steam Boats 2 02-28-2003 10:35:21 AM
Ball or Cone for Hercules? Chris Kirk Antique Engine Archives 1 09-15-2002 07:23:53 PM
1/2 inch Ball or Cone Mufflers Hal Davis Antique Engine Archives 0 09-10-2002 12:12:19 PM
