Waterloo & Contract Engines
this thread has 57 replies and has been viewed 13482 times
Old 01-22-2014, 02:36:09 PM
Engine Whisperer Engine Whisperer is offline
Defective Email Address
Default Re: Waterloo & Contract Engines
It's a George Miller-built engine, could have been a Faultless or a contract engine for Colbert American Boy.
The Following User Says Thank You to Engine Whisperer For This Post:
Old 01-22-2014, 06:52:05 PM
MedicHamilton's Avatar
MedicHamilton MedicHamilton is offline
ok thanks bill. anyone have old ads on these. or pictures?
Bryan K Hamilton
Old 01-23-2014, 02:25:23 PM
Here is my John Smyth Faultless #94947, 5-1/2 X 10, 36" flywheels. It has the date on the governor weights but I have never recorded them. It has about enough original red paint to cover one side of a wooden match head. Was originally skid-mounted and when I got it the oiler and the ignitor were missing, also missing about 1/3 of the cast fuel tank mount. This engine sat outside from the late 20's to 2001 and I am the third owner. It was stuck for real, had to sleeve the front 2/3's of the cylinder and make a copy of the fuel tank, it was smashed up pretty good at some point when the engine decided to rest on one side. Very nice runner, my favorite engine.
The Following 7 Users Say Thank You to Engine Whisperer For This Post:
  #34
Old 01-23-2014, 05:46:27 PM
Rich Mueller Sr's Avatar
Rich Mueller Sr Rich Mueller Sr is offline
Nice engine Bill , almost identical to the one I got ,I think that might be the next size bigger!, Looks like the bolts might be almost gone that hold the hopper on, I replaced all of the ones on mine and the gasket, almost had no bolts!! Been there done that with a Round Rod, it actually was loose and started seeping like that.. I need to find a nut for the Luk carb and I have some 1/4 galv pipe to replace the copper 3/8th comp fittings now, and get the tank and box right kind of temp to see what it would run like.....And I missed a splash sheild on here ,but a dollar short and day late
United Gasoline Engine Registry www.augermo.com
Last edited by Rich Mueller Sr; 01-23-2014 at 05:53:31 PM. Reason: spalsh sheild and spelling
Old 01-23-2014, 07:00:11 PM
New bolts in the hopper. When I was putting it together a very good friend was urging me to just use a bead of silicone on it, just to be obnoxious I cut a thick paper gasket for it and refused to use any sealer on it. It doesn't seep much when it's warm and I figure it kinda' matches the the original look. You don't get a finish like this one has overnight! Check out the pitting on the crankshaft and hub.
The Following 2 Users Say Thank You to Engine Whisperer For This Post:
  #36
Old 01-24-2014, 12:41:47 PM
Nice patina on that one!! At least it didn't have calcuim chloride in the hopper, you can actually see the sleeve on the little Waterloo boy that is cast dated, the cyl fell out when chris bored and sleeved it, and the piston still has pits where it ate through the cyl wall! Runs good 4 days straight at Mt Pleasant, Ia. last year....
Old 01-26-2014, 12:53:28 AM
Steve Alt's Avatar
Steve Alt Steve Alt is offline
John, Here's a picture I've had filed away of a Russell engine I seen some years back.
Name:	Russell Engine.jpg
The Following 4 Users Say Thank You to Steve Alt For This Post:
  #38
Old 01-26-2014, 08:22:14 AM
RustyRelics UK's Avatar
RustyRelics UK RustyRelics UK is offline
Here is a 1,1/2 hp Van Duzen, Roys & Co. which is in our collection
http://www.youtube.com/watch?v=Zt7fU8CMMhk
Carl Hargreaves
The Following 3 Users Say Thank You to RustyRelics UK For This Post:
  #39
Old 01-26-2014, 09:36:43 AM
Mike Schweikert's Avatar
Mike Schweikert Mike Schweikert is offline
Images: 26
Here is my 1909 4hp Waterloo, serial 12065. It had been sitting for over 40 years before I acquired it.
It still has the original pinned piston rings, but has new valve guides, and valve work done. It had a small piece broke out of the bottom of the edge of the cylinder, probably due to a rod failure it its life. I found that the piston pin bolt end had been welded many years ago, and was still strong, so a new piston pin was made to correct for wear, and the original bushing slightly reamed. It is my favorite of the bunch.
Mike Schweikert
Jamison PA
See my videos at: http://www.youtube.com/user/standardtwin1
The Following 2 Users Say Thank You to Mike Schweikert For This Post:
  #40
Old 06-16-2014, 09:12:38 AM
Scooby Scooby is offline
Have you ever heard of a Colbert American Boy? No tag but this is what they are claiming it is. Thanks Bob boblinda66@gmail.com
The Following User Says Thank You to Scooby For This Post:
Waterloo Contract, one of 65+co. engine Rich Mueller Sr Antique Gas Engine Discussion 4 12-06-2013 10:15:27 AM
Waterloo Contract Engine's (Not Waterloo Boy's) Jim Martin Antique Gas Engine Discussion 10 05-20-2013 05:31:33 PM
Possible Waterloo contract? Help ID! jd37aw Unidentified Engines 3 05-09-2012 02:49:54 PM
T. Eaton & Co. contract Waterloo age? deh375 Antique Gas Engine Discussion 1 12-13-2009 10:50:26 PM
waterloo contract engine C. Props Antique Engine Archives 2 10-21-2001 10:39:22 AM
