Fuller Johnson pump engine
this thread has 2 replies and has been viewed 283 times
Old 11-05-2018, 08:58:17 PM
mmayer mmayer is offline
Default Fuller Johnson pump engine
Fuller Johnson ignition. picked up a FJ pump engine can anyone help me out with the ignition wiring . Do I use a low or high tension coil and how do I wire it correctly with a spark plug Thank you ..
Old 11-05-2018, 09:27:01 PM
Nick's Avatar
Nick Nick is offline
Images: 41
Default Re: Fuller Johnson pump engine
You need a high tension coil - either a proper stationary gas engine coil or a model T coil. Substitute the 4 dry cells with a 6V gel cell battery then wire it up like the diagram.
Old 11-05-2018, 09:48:44 PM
ScooterBob ScooterBob is offline
Here's a bunch of buzz coil info, including the terminal locations for the model T coil. The T coils are pretty easy to find, usually see a couple in every antique store, and always at engine show swap meets.
https://www.old-engine.com/magbuz.htm
If you have further questions and want to discuss, shoot me a private message, I'm just up the road about 40 minutes of so.
Fuller & Johnson Pump Engine oliver70rc Antique Gas Engine Discussion 3 12-05-2017 11:03:11 AM
Fuller & Johnson Pump Engine AKMark Antique Gas Engine Discussion 4 04-22-2016 04:54:06 PM
pump for 1923 Fuller Johnson pump engine Mayatag Bob Antique Gas Engine Discussion 3 08-12-2013 09:42:59 PM
Fuller and Johnson pump engine Babs8070 Antique Gas Engine Discussion 6 11-06-2008 10:19:15 PM
Fuller & Johnson Pump Engine Wayne Sanders Antique Engine Archives 0 04-27-2000 01:20:02 AM
