Associated 8hp engine
this thread has 5 replies and has been viewed 722 times
Old 11-06-2018, 03:51:04 PM
Kevinrhall Kevinrhall is offline
Question Associated 8hp engine
Hello ,recently acquired off ebay!!
help information on 8hp engines few parts missing ,fuel tank and fuel lines measurements etc ,petrol paraffin, crank guard, exhaust muffler,oiler part no G378 throttle rod support bracket??
Believed to have worked all its live at SCARISBRICK FARM LANCASHIRE UK
driving two saw benches, approx., purchased by scarisbrick estate in the 1920,s
Removed and some restoration done in the late 60,s stored for 50 years
Any help information would be appreciated thanks in anticipation
ID:	322269   Click image for larger version
ID:	322270   Click image for larger version
The Following 4 Users Say Thank You to Kevinrhall For This Post:
Old 11-06-2018, 04:18:31 PM
StuartUK StuartUK is offline
Default Re: Associated 8hp engine
Very nice engine .I see it sold a few weeks ago.Is it the rear governor rod cast iron bracket thats missing (behind the flywheel) ??.The front support bracket (on the cylinder head) also supports the side bar
The Following User Says Thank You to StuartUK For This Post:
Old 11-06-2018, 05:57:51 PM
Hi Stuart yes that's the bracket, had a good look round to find it ,but it never showed up, also one main bearing cap stud missing regards
Kevin
The Following User Says Thank You to Kevinrhall For This Post:
Old 11-07-2018, 03:42:03 AM
The bearing cap stud is not a problem.......just remove one of the others and take it to an engineering company for them to copy.The thread will be UNC .You could make a bracket from steel so you can at least run the engine.If you ever find an original cast one you can then replace it.As it happens my 6 Mule-Team engine also has a "home made" steel bracket fitted !
Old 11-07-2018, 04:47:06 PM
Hi Stuart, thanks for the information, I,m hoping to source the missing parts etc do you know if the diameter of the fuel lines is critical to the running of the engine?
Old 11-07-2018, 06:14:11 PM
The diameter of the pipes must fit on the 1/4" brass check valves.The fuel pipes and fittings for my 6 Mule Team are the original steel ones but i have no check valves as yet (impossible to find original CRANE 125 ones !!).I still have to sort out the fuel system for my engine.
