Removing Delco Flywheel
this thread has 2 replies and has been viewed 2103 times
Old 02-04-2001, 01:07:07 AM
Larry Kastens
Default Removing Delco Flywheel
I need some help on how to remove the flywheel on a Delco 850 Light Plant. The gib key is removed and a liberal amount of Kroil has been applied to the crankshaft. I have repeatedly heated the hub red hot, used a wheel puller, and a slide hammer. The wheel puller and slide hammer jaws are attached to the back side of the flywheel. Thanks.
Old 02-04-2001, 11:01:44 PM
Larry Kastens
Default Re: Removing Delco Flywheel
Thanks to all who read my inquiry. I was successful in removing the flywheel this afternoon. The problem was that the first inch of the crankshaft was pitted, preventing the flywheel from sliding off easily.
Old 02-08-2001, 10:08:50 PM
Guy (GUS) Simms
Larry: Usually, once you apply Kroil, you just sit back and listen for the "clunk" when your flywheel slides off the shaft.
Removing the flywheel from a 5.0 CCK tdarden Onan Generators 24 03-08-2014 10:15:30 PM
Removing a flywheel Keith Johnson Hit & Miss Gas Engine Discussion 7 10-06-2009 07:04:54 AM
Removing flywheel or BobM Hit & Miss Gas Engine Discussion 4 04-28-2008 03:22:22 PM
Removing an LA flywheel Norm Antique Engine Archives 6 12-04-2001 09:50:26 PM
Removing Delco Flywheel Larry Kastens Antique Engine Archives 3 02-04-2001 10:57:58 PM
