Lalley Light Plant
this thread has 4 replies and has been viewed 2701 times
Old 03-25-2001, 12:37:09 PM
Larry Hendel
Default Lalley Light Plant
I have awuired a Lalley Light Plant that apears to be fairly complete. It is type H U, and has two switches one switch has CH printed on it that I take to be charge control and the other has nothing on it but appears to be ignition control as it has electric (points,condensor,coil) type ignition, Which way does it turn? Being a 2 cycle engine could go either way butwhen connect batteries tendes to want to turn reverse to the crank position that is on gen end. Any ideas, information would be much appreciated. Thanks, Larry
Old 03-27-2001, 07:49:19 PM
Guy (GUS) Simms
Default Re: Lalley Light Plant
The only Lally info I have is for a model F, which is evidenly different from yours. The CH switch is most likely a Cutler-Hammer charging regulator/reverse curent relay, which was popular on a lot of light plants. Some have the start and stop contacts built in. My info says the engine turns opposite a normal gas engine, that being "anti-clockwise". Chances are it is a 32 volt DC, but don't hold me to that
Old 03-27-2001, 11:31:33 PM
Don C. Wiley
Larry;
I have only seen one Lally Light plant and didn't pay much attention to it, but I just restored a "Tiny Tim" for a friend and I had taken it completely down to bare frames. When I got it all slicked up and painted and assembled it ran backwards. I discovered when I replaced the brush plate I got it 90 degrees out. When I turned it back 90 degrees It turned the right direction.
Gus probably knows more about your Lally than I do. It might just be that it runs counter clockwise.
Get the engine fixed up ready to run and crank it and if it starts and/or intakes and exhausts properly you will know which way it should turn. You might want to check to see if the spark occurs at the right time as well.
I hope we have helped you some.
"DELCO DON"
Old 03-28-2001, 02:05:49 AM
Frank Eddy
Hi Gus, I have sent some copies of a model L Lalley Light manual to Loren Erwin of Carthage, Mo. He has some info on the model HU. He is looking for a manual for the F. Maybe you can trade information with him. His e-mail is engines@ipa.net Good luck.
Old 03-28-2001, 11:53:15 AM
Larry Hendel
Thank You all for your responses. It is 32-40 volts and fires as if will run counterclock wise. I only primed as fuel system needs work. also tks Harry for the site! Larry
Lalley Light Plant Info ? Paul Generators & Electric Motors General Discussion 4 01-30-2014 05:37:47 PM
Lalley Light Plant Paul Voss Delco and other Low Voltage DC Light Plants 22 08-01-2012 11:34:59 AM
Lalley light plant gen? Ron Davis Antique Gas Engine Discussion 1 11-11-2008 04:17:10 PM
lalley light plant model F Charles Generators & Electric Motors General Discussion 0 04-11-2003 10:59:05 PM
Lalley Light Plant W. D. McDonald Generators & Electric Motors General Discussion 0 03-04-2001 09:14:28 AM
