Crank for Moving 1/3 and 1/2 Scale Engines
this thread has 1 replies and has been viewed 401 times
Old 07-31-2018, 06:32:09 PM
chrsbrbnk chrsbrbnk is online now
Default Crank for Moving 1/3 and 1/2 Scale Engines
I had built a hand crank that keyed on to the fly wheel shaft and key this has been a huge help in loading and unloading or just moving around without steam up. Didn't realize how useful the crank was until I thought I had lost it at the last show. moving the engine around with out it is a lot more of a work out. turns out if you toss it in the bunker on top of the coal the vibration of trailering lets it sink down under the coal at least I didn't have to make a new one
The Following User Says Thank You to chrsbrbnk For This Post:
Old 08-07-2018, 11:50:16 AM
skugger skugger is offline
Default Re: Crank for Moving 1/3 and 1/2 Scale Engines
wouldn't mind seeing a picture of the crank in action, if you have one handy!
Moving Larger Engines? FLAman Antique Gas Engine Discussion 28 02-09-2017 11:01:30 AM
Your workshop, and moving engines around Billinoregon Antique Gas Engine Discussion 30 07-05-2015 08:43:18 AM
More engines moving Kevin Kusel Antique Gas Engine Discussion 2 07-18-2010 07:56:33 AM
Moving and lifting engines Clark Bigger Antique Gas Engine Discussion 10 04-13-2008 11:53:39 AM
Moving big engines Doug Edwards Antique Engine Archives 12 08-24-2002 01:23:26 PM
