I'm looking for a wiring diagram and advice on an Onan DJA-3CR/3005U
this thread has 5 replies and has been viewed 1425 times
Old 10-30-2011, 01:31:14 PM
Carpentersdonkey Carpentersdonkey is offline
Default I'm looking for a wiring diagram and advice on an Onan DJA-3CR/3005U
Hello knowers of all things Onan, I live off the grid in Oregon and just picked up a single phase 120/240 vac 3kw Onan genset serial number A780297029. My Genercrap 12k Guardian finally put me out of my misery by seizing up, and I want to hook up the small Onan as my backup until I can afford a new more full sized model with leather seats. I know a 3kw isn't much of a replacement for the 12kw that just died, but that thing rarely put out more than 3kw anyway. My problem now is that I'nm not getting 220v across any of the leads coming from the generator, so I hooked it up 110v and under load the frequency drops to 52hz. If any one can push me in the direction of a proper wiring diagram for this model and some advice it would be much appreciated.
Old 10-30-2011, 04:16:45 PM
BTPost's Avatar
BTPost BTPost is offline
Images: 1
Talking Re: I'm looking for a wiring diagram and advice on an Onan DJA-3CR/3005U
I have the manuals, where do you want to send them.....
Bruce in alaska
Old 10-30-2011, 04:20:11 PM
Default Re: I'm looking for a wiring diagram and advice on an Onan DJA-3CR/3005U
i was hoping you would reply. I've seen your name on several threads. You can carpentersdonkey@yahoo.com. Thank you
Old 10-30-2011, 04:33:05 PM
BTPost's Avatar
Images: 1
check you email Box in about 10 minutes there will be two emails for a total of about 15MBs of .PDF files....
Bruce in alaska
Old 10-30-2011, 04:55:18 PM
Recieved thank you. Problems persist though, this morning when I started this thread the generator was running and I attempted to adjust the governor while under load, I let it run for a few minutes and went inside to disconnect the load and see how the generator reacted. Once there was no load the Gen rpm increased and by the time I got back outside to check the readings the gen shut itself off and now it won't start. It decompresses as soon as I let off the starter switch.
Old 10-31-2011, 12:30:55 PM
BTPost's Avatar
Images: 1
Look at the wiring diagrams that I sent you.... follow the voltage to the Decompression solenoid to the Battery. somewhere you have a disconnect....
Bruce in alaska
Onan 12.5JC wiring diagram djackman Onan Generators 28 07-18-2017 01:45:36 PM
Old GE Motor, looking for wiring diagram or advice paulmars Generators & Electric Motors General Discussion 14 03-10-2010 08:52:15 PM
Onan 5go wiring diagram TomFG Onan Generators 0 02-23-2010 11:34:43 AM
Onan 4.0 CCK wiring diagram 37 racin Onan Generators 8 07-16-2008 09:47:57 PM
wiring diagram Onan W2C werfymmot Onan Generators 15 10-31-2004 04:04:54 PM
