GE 2KW DC Generator+6 hp Tecumseh
this thread has 1 replies and has been viewed 500 times
Old 06-11-2019, 09:39:00 PM
930dreamer 930dreamer is offline
Default GE 2KW DC Generator+6 hp Tecumseh
I picked this up as a project for my 6 year old grandson and I to mess around with. Model is 5K225B26, wondering if anyone had any information on the generator portion?
ID:	336971   Click image for larger version
ID:	336972   Click image for larger version
ID:	336973   Click image for larger version
The Following User Says Thank You to 930dreamer For This Post:
Old 06-11-2019, 11:30:12 PM
Default Re: GE 2KW DC Generator+6 hp Tecumseh
Neat! I do love Direct Current machines.
You could slow it down some, and cut in some field resistance to get it down to 120 volts so you could run light bulbs and series motor equipped tools. Would be 1 kW continuous then. Or could run pairs of 120 volt bulbs in series.
The device that outputs 4 - 20 ma is designed to interface with a Programmable Logic Controller (PLC). Looks like it converts a 0 - 1000 ohm signal into the standard 4 - 20 ma signal used with those systems. I have no idea what it does with the generator.
The Following 2 Users Say Thank You to Vanman For This Post:
Coleman Powermate Generator (Tecumseh Engine) - No Ignition Spark DustyBar Generators & Electric Motors General Discussion 16 12-06-2017 03:22:59 PM
Tecumseh HH100 - 10hp - Generator Removal JBPII Hit & Miss Gas Engine Discussion 7 03-03-2017 07:53:59 PM
Tecumseh Generator Skandia600 Small Air Cooled Gasoline Engines 0 11-10-2013 09:48:31 PM
Tecumseh generator engine id help Tecumseh man Generators & Electric Motors General Discussion 6 07-30-2012 07:43:48 PM
Tecumseh Generator Motor Jim Richert Small Air Cooled Gasoline Engines 2 03-20-2010 09:44:04 PM
