Go Back   SmokStak > SmokStak® Vintage Electrical Equipment > Honda, Yamaha, Kawasaki, Isuszu Generators
Dayton 3CZ15A with 3 cyl. diesel engine
this thread has 5 replies and has been viewed 289 times
Old 08-11-2019, 08:47:31 PM
bluefields bluefields is offline
Default Dayton 3CZ15A with 3 cyl. diesel engine
Hi all,
I just picked up this unit, not sure if this is the right forum. It has a one liter 3 cylinder diesel that may be Asian? I have the manual, but it doesn't say who the manufacturer is. The wiring compartment appears to have been home to chipmunks. Any insight would be greatly appreciated. The previous owner said he received it as new, but never installed it or ran it. Other than to start the engine last week.
Thanks, Dave
ID:	341212   Click image for larger version
ID:	341213   Click image for larger version
ID:	341214   Click image for larger version
ID:	341215   Click image for larger version
ID:	341216   Click image for larger version
Old 08-11-2019, 08:53:51 PM
Default Re: Dayton 3CZ15A with 3 cyl. diesel engine
Okay, as soon as I posted I saw that several others had postings for their Dayton/Generac 8kw generators. Which is apparently what my unit is. I'll read further and see if I can find more info on the engine. If I can figure out how I'll move my post to the correct forum.
Old 08-11-2019, 09:26:21 PM
Email NOT Working
That would be the common Shibaura engine used in some forms to this day. S753 I think you will find cast into the block below the fuel filter.
Pretty good unit for the most part. It takes some hunting to find some parts but not quite an orphan.
Old 08-12-2019, 10:56:08 AM
Thanks for the engine ID, S753 is cast into the block. I'll start hunting for parts (availability). The generator was never hooked up, but time ,weather and critters have damaged the wiring for the control panel.
Old 08-12-2019, 10:59:43 AM
Email NOT Working
Many tiny Ford tractors from the late 80s/early 90s used that engine so that info can be used to source parts.
Old 08-17-2019, 01:54:02 AM
Motorhead's Avatar
I owned an identical Dayton 8kw just like yours. It was a good set. It is a Shibaura engine, mine ran well. Mine needed a water pump when I got it and not knowing, I bought it through Generac and paid $430.00 for it! Found out later that I could buy a FORD tractor same pump, 1/3rd the price. One issue I could never get rid of was that when I had incandescent lights plugged into it, I couldn't get rid of the flicker, even with adjusting the voltage regulator flicker feature.
My 1939 WILLYS Pickup.
Bought in 1971
Dayton/Generac 8KW diesel. Voltage difference on each leg. Motorhead Generac Generators (SEARS, etc.) 1 09-27-2011 02:29:12 PM
Ran the house today with the Dayton/Generac 8K Diesel Motorhead Generac Generators (SEARS, etc.) 14 06-27-2011 11:46:22 AM
Dayton/Generac 8KW diesel finished and installed Motorhead Generac Generators (SEARS, etc.) 6 01-16-2011 12:51:48 PM
My Dayton/Generac 8KW Diesel genset Motorhead Generac Generators (SEARS, etc.) 9 12-27-2010 03:39:25 PM
Dayton (WW Grainger) 5kW Diesel B.Ikard Generac Generators (SEARS, etc.) 3 09-08-2008 12:13:07 AM
