Homelite G-7200 Generator Questions
this thread has 4 replies and has been viewed 518 times
Old 06-22-2019, 08:39:37 PM
jibs1723 jibs1723 is offline
Default Homelite G-7200 Generator Questions
Hi everyone. I've been looking through smokstak for a long time but i finally have a question i can't find an answer for. I picked up a homelite g-7200 generator recently. it has a Kohler k-582 engine and it rated at 7200 watts. It runs and makes power but i found that the circuit breaker isn't hooked up so i was looking for a wiring diagram to try and unscramble what someone else did. Also would just like to know more about it. For instance theres what looks to be a small little solenoid on the carb that i have no idea what it does. Does anyone have any info or experience with these units? Haven't had much luck turning anything up on them.
Thanks!
Old 06-23-2019, 09:24:02 AM
Joe Romas Joe Romas is offline
Default Re: Homelite G-7200 Generator Questions
I don't know anything about your unit.
But solenoids on carburetors are a different story.
Depends on where on the carburetor the solenoid is.
If it's connected to the speed butterfly someway it's for a slowing engine speed down when there's no load to conserve fuel.
If it's a newer one and on the bottom of the float bowel it's to shut off the gasoline flow when you shut the unit off for pollution purposes.
Old 06-25-2019, 07:14:05 PM
Its neither of those. I'm familiar with standard stuff like that. This goes into the spot where on the old Kohler carbs i think the idle circuit air bleed screw would go. I was thinking it might be an start enrichment circuit that works in conjunction with the choke but i wasnt sure as I've never seen anything like this before on a small engine.
Old 06-25-2019, 07:53:20 PM
radiodoc radiodoc is offline
Picture(s) would be nice I think.
Old 06-26-2019, 07:20:22 PM
Haha yea that would help. See pics attached.
ID:	337911   Click image for larger version
ID:	337912   Click image for larger version
ID:	337913   Click image for larger version
HomeLite Generator needs help!! Duffy11 Generators & Electric Motors General Discussion 6 09-25-2011 08:13:59 PM
7200 watt Generac... nodrtbike Generac Generators (SEARS, etc.) 10 01-03-2010 06:04:21 PM
Homelite Model 17 ignition questions twobyfour Chain Saw Collectors 10 12-28-2009 09:37:14 PM
Homelite Mod. 20 5D28 23A Questions Carter Military MEP and Aircraft Gen-Sets 23 10-10-2009 05:57:34 PM
Old homelite generator needs help Odis Generators & Electric Motors General Discussion 0 08-28-2004 10:01:54 PM
