Champion model 10047 additional cooling
this thread has 1 replies and has been viewed 368 times
Old 07-09-2019, 10:37:51 PM
deno deno is offline
Default Champion model 10047 additional cooling
Correction: Champion model 100477
Hi!
This will allow me to take the Onan BGE 4.0 offline to a shop to have various maintenance on it. It runs fine but it may have an exhaust leak and has a crank leak on the fan side, and could use a new muffler. Too loud.
Champion model 100477 sat at a pawn shop w gas in it for several months. Been running Berryman's through the carb. Changed the oil etc.
There is an access panel on the side to get to oil fill, drain, spark plug (replaced w a NGK laser iridium), air filter. I wonder if putting a blower on the outside injecting air into this area through the panel (or leaving the panel off) would be good. Idk how the unit's airflow system works. It doesn't seem to have a built-in blower. Correction: it does.
Specs say it can operate up to 40° centigrade. But we all know this is b.s. with the type of enclosure it has, loads etc. I'd be much more comfortable with a blower injecting (relatively) cold, fresh air in on the access panel side.
I already possess a small squirrel cage blower meant for a fireplace. I'd say it does somewhere around 300-400 cfm. That's 120vac. I could use that.
I also have a brushless 12v DC blower that does 42cfm at 41.10mm of static pressure. Pretty sure it can run directly off the genset's unregulated 12v DC output. (blower says 7-14v operating voltage).
The genset will have to have a 'hood' to protect it from the weather. It will be enclosed on 3 sides with plenty of airflow between it and the walls (min 1.5 ft on sides and rear, several feet on front). It will be mounted down to steel studs and track. It doesn't seem to have 'mount points' per se but I will figure it out.
Old 07-12-2019, 03:48:32 AM
autosparkii autosparkii is offline
Default Re: Champion model 10047 additional cooling
From having dismantled a few of these style, I don't think you would hurt anything.
Only thing I could think of is that the air flow seems to come in and over the inverter first.
Adding ar from the side may slow or reduce that air flow?
The Following User Says Thank You to autosparkii For This Post:
Convert diesel stationary engine from hopper cooling to radiator cooling Jhoechtl Vintage Diesel and Oil Stationary Engines 3 04-16-2019 01:12:04 PM
15hp Fairbanks Morse z model cooling tank Edmidd Hit & Miss Gas Engine Discussion 0 01-14-2019 06:36:06 PM
Champion 2000i Parts (where can I find them) model 73536i Shelby04861 Honda, Yamaha, Kawasaki, Isuszu Generators 3 09-26-2017 08:00:48 PM
cushman model c cooling tank economyminded1 Hit & Miss Gas Engine Discussion 3 01-18-2017 10:22:17 PM
1907 Buick Model G cooling Happy Old Iron Antique Autos and Trucks 5 03-04-2009 12:04:15 AM
