Winco WC6000HE-D stator rewind
this thread has 2 replies and has been viewed 322 times
Old 07-13-2019, 03:34:38 AM
LeoBuchner LeoBuchner is offline
Default Winco WC6000HE-D stator rewind
I have a Winco WC6000HE-D generator bought at a local auction. I knew it wasn't working but at $18 I figured it was a reasonable speculation. The engine is in good condition and runs like a champ but the generator section produces nothing.
I've tried reflashing the generator several times with no results. There is essentially no output (less than 1V AC) from the generator when running.
The rotor appears in reasonable condition which is a good thing as it won't release from the driveshaft.
After pulling the stator it appears that the previous owner cooked the inner layer of stator windings. The generator fan doesn't seem to move much air through it so this is not surprising.
The local generator shop quoted $400 to rewind the stator. It is a reasonable price but I can't afford it.
I have the necessary 18 AWG magnet wire but I've never rewound a generator. Winco kindly supplied the winding specification (see attachment) but I can't figure out what is being specified in the stator winding section -- I've highlighted that in purple. Clearly they are referring to something about the 17 turns on the winding.
a) Is this rewind a project I can reasonably attempt myself and expect success?
b) What is that stator winding spec referring to?
Old 07-13-2019, 01:19:53 PM
AlanR AlanR is offline
Default Re: Winco WC6000HE-D stator rewind
a) - IF you carefully remove the old windings, noting all details of their arrangement and connections, then duplicate with new wire, slot liners, lacing, etc AND have your local rewind shop dip and bake the stator afterwards, yes, it's doable.
b) The stator winding spec is in 2 parts - winding 1, first part says 17 turns TOTAL of 5 strands of #18 in parallel, second part says those 17 turns are arranged as 1 turn spanning slots 5 and 8 leading to 4 turns spanning slots 4 and 9 leading to 4 turns spanning slots 3 and 10 leading to 4 turns spanning slots 2 and 11 leading to 4 turns spanning slots 1 and 12. Similar arrangement for windings 2 and 3.
Alan
The Following User Says Thank You to AlanR For This Post:
Old 07-13-2019, 02:51:17 PM
Thank you, Alan. Money is short but time and patience I do have. Now that I know the coil winding configuration I can probably get along with good pictures taken along the way.
I'll find out what it will cost to have the stator potted and baked and then, deo volente, I can get started on the teardown.
The Following User Says Thank You to LeoBuchner For This Post:
How-To, Exciter Rewind (both Stator & Rotor) a31ford Onan Generators 21 02-19-2017 07:26:40 PM
Stator rewind vs new Gridless Generac Generators (SEARS, etc.) 3 01-26-2016 10:10:42 PM
Generac Stator Rewind? DPE Winding? ProudDad2005 Generators & Electric Motors General Discussion 29 10-30-2013 08:25:07 PM
Marine Generator Stator - Average lifespan? Rewind? Rotor too? antinucci Kohler Generators 24 04-22-2011 08:56:31 AM
Onan 25EC-4R8/302D Stator rewind questions Old Style Onan Generators 22 12-29-2010 03:10:35 PM
