Leroy-Somer capacitor
this thread has 2 replies and has been viewed 343 times
Old 07-15-2019, 01:44:22 PM
Default Leroy-Somer capacitor
I have a Leroy-Somer light tower generator. A loose connection on the capacitor melted the solder and the spade fell off. I was able to repair it and it made it through the storm outage. The capacitor is 70uf, 450 volts. Can I use any capacitor with these specs or should I buy one of the regulator capacitors, the ones I've seen are about $100.
Old 07-15-2019, 01:54:14 PM
Birken Vogt Birken Vogt is online now
Email NOT Working
Default Re: Leroy-Somer capacitor
Just make sure it is a "run" capacitor and not a "start" capacitor. I have done this a few times with caps from the HVAC supply and it always worked so far.
The Following 2 Users Say Thank You to Birken Vogt For This Post:
Old 07-15-2019, 07:16:39 PM
circuitman circuitman is offline
just make sure the voltage rating & uf are the same. you use a higher voltage. but keep the uf's close. like birken said it has to a run cap. there usually silver metal cans.get them on ebay pretty cheap.
The Following User Says Thank You to circuitman For This Post:
Cummins/Leroy Somer 50K 1 ph I like oldstuff Generators & Electric Motors General Discussion 0 04-18-2014 05:31:02 PM
Leroy-somer lsa37 m6 a 1/4 F. Moore Generators & Electric Motors General Discussion 8 02-21-2014 04:24:50 PM
Leroy Somer LSA 35 replacement cap djackman Generators & Electric Motors General Discussion 1 12-02-2012 02:39:13 PM
Leroy Somer 6K gen Kubota 850? john11139 Generators & Electric Motors General Discussion 6 09-03-2012 08:59:37 PM
Help with Leroy-Somer Generator DLeach Generators & Electric Motors General Discussion 9 02-16-2011 11:41:01 PM
