Go Back   SmokStak > SmokStak® Antique Engine Community > Oil Field Engines
Oil Field Engines A gathering place for OFES members otherwise known as "Oafs". Basically, if you like "BIG OLD GREASY RUSTY OIL FIELD ENGINES, you're in the right place. Founded by Russell Farmer.
Regulator For Propane Needed
this thread has 15 replies and has been viewed 1451 times
Old 09-17-2017, 10:59:12 AM
Rex Piekarczyk's Avatar
Rex Piekarczyk Rex Piekarczyk is offline
Images: 8
Question Regulator For Propane Needed
I' m trying to get my friend's engine running to sell, but I've never worked with propane fuel delivery. It ran @ 10 years ago on propane at the seller's location and has been in climate controlled storage since.
Hand written instructions included indicate gas pressure to carb as 1 to 2 oz pressure, 4 oz max. I have an "wc gauge & found that 2 oz = 3.5"wc.
I need to get whatever is necessary that goes between a gas grill propane tank and this carb.
If anyone has this setup or can direct me to a source please let me know.
Thanks,
Rex
Name:	dbfmengine (557x600).jpg
ID:	291474   Click image for larger version
Name:	dbfm2 (600x600).jpg
ID:	291475   Click image for larger version
Name:	dbfmcarb1 (600x380).jpg
Old 09-18-2017, 06:45:47 PM
con-rad con-rad is offline
Default Re: Regulator For Propane Needed
Just use a BBQ grill regulator, they are set at 11" WC and should work fine. They can be had for about $15 new.
good luck!
connor
Old 09-18-2017, 07:06:35 PM
Images: 8
4oz max = 7"wc max.
Old 09-18-2017, 07:34:03 PM
Reed Engine's Avatar
What I know, most engines will run at from 2-6 oz. 6 oz = 10 1/2" wc. 4-6 would probably be the better range. So 7" - 10 1/2"
The Following User Says Thank You to Reed Engine For This Post:
Old 11-09-2017, 11:53:17 PM
dkamp dkamp is offline
Running it direct with 11" wc will work, but it will be free-flowing... the equivalent of just dripping gasoline into the throat of a running engine, rather than with the KN in place, the engine's DEMAND will DRAW it.
In the fields, with a basically constant load, running free-flow worked fine, as long as the engine didn't shut down for some other reason. IF it did, the fuel would continue to flow out...
Of course, if the engine was running on well-head gas, if the engine stopped, the wellhead gas would either continue to flow (if there was sufficient geologic pressure) or would drop way off or stop after the pumping stopped... so free-flow wasn't an unreasonable scenario.
Actually, if you want it to run RIGHT... connect a 20lb or larger propane bottle's vapor outlet (not liquid) to a gas-grille regulator, then the output of that to a Garretson KN demand regulator INPUT. Connect the OUTPUT to the input of your Impco (or clone) 100-series vaporous carbeurator.
The other option, is to connect the 20lb tank directly to an IMPCO J, and then from the J to your CA-100.
The IMPCO J is a combination dual-stage regulator/vaporizer/demand regulator... tank pressure on the input, and demand level output. IF you needed liquid-withdrawl, it'd evaporate, too, but to do that, you'd need to pipe engine coolant through the body to provide heat for evap.
Propane pressure out of the tank varies... on a really hot day, you might see 230psi. On a -30F day, you might get five psi... sometimes less.
When propane is passed out of the tank, it must be pressure-controlled. Gas grilles use a regulator that does 'two stage' operation- drops tank pressure all the way to 11" w.c. in one device... Residential propane systems, though, typically use two, and sometimes three regulation stages before getting to 11" w.c... The common first stage pressure is either 10psi or 2psi, which runs underground to the house, and then another at the house that drops to 11" w.c. for appliances inside.
The Impco J has both regulation stages AND demand reg in one unit. A Garretson KN takes it from 11" w.c. Both connect to your CA-100.
What's the difference in the long run? Well, if it was a big, hungry engine, or on a particularly small tank (that doesn't have enough evaporation volume to provide stable output pressure under load), you'd need liquid withdrawl and evaporation. If you have a small enough demand, and large enough tank for direct vapor, running two stages of regulation and a Garretson KN will work best. My observation is that the Garretson KN is much more sensitive to load variation than the Impco J.
Have I thoroughly confused you?
The Following 5 Users Say Thank You to dkamp For This Post:
Old 11-10-2017, 09:50:37 AM
dcamp, not trying to hijack this thread but could you use a gas grill regulator and then off of that use an acetylene torch regulator to fine tune it?
I am getting ready to set up my 15HP reid on a hot tube and I read where you can run the feed to the hot tube unregulated, but the feed to the engine itself needs a regulation device. I cannot handle the large 100lb propane tanks so I am going to purchase two 40 lb bottles. Any suggestions on my setup would be appreciated. Thanks
Old 11-11-2017, 07:32:58 PM
I believe that acetylene regulators shouldn't be used with propane, due to compatibility issues of the gas vs. rubber seals and diaphragm. This is only what i've read though, never tested it.
Also a torch regulator operates around 5-15PSI outlet pressure, so I don't think feeding it with 11"WC would work very well.
There are adjustable low pressure propane regulators out there that you could use to get whatever pressure you want.
Old 11-11-2017, 09:06:46 PM
Images: 8
Which one? JB, JB-2, JB-3, JB-2ULC, JB-C-140, JB-C-725, JB-L-377, JB-R, JO, JO-2.
Old 11-11-2017, 10:34:00 PM
justme7917 justme7917 is offline
i seen guys use propane on acetylene cutting torches just to save money
Old 11-12-2017, 08:32:39 AM
Yes, a lot of the old time junk yard guys used propane in their cutting torches as it was cheaper and more readily available.
Old 11-12-2017, 05:38:47 PM
My cutting torch is a 500 gal propane tank out back. We keep the oxy cylinders inside and have valves and regulators mounted on the wall.
Old 12-11-2017, 12:47:38 AM
On a gaseous fuel system fed by bottled gas, you need at least ONE regulator to limit the tank's pressure (of anywhere up to 200psi) down to 11" water column or so.
After that, you need a demand regulator... aka 'zero governor'... a negative pressure device that flows fuel only when there's an ENGINE DEMAND to do so (slight vacuum).
Think of it as a regulator that, instead of putting out 5psi at lower limit, is set to ZERO PSI... that means... it won't flow ANY fuel. When you apply a slight vacuum, it flows fuel, and is sensitive enough to STOP flowing fuel when there's no vacuum.
You COULD take a gas grill regulator, an acetylene torch regulator, and cobble up some combination to fuel the engine... it WILL work, but it won't demand regulate, it won't shut off, and it won't be stable. As an added feature, it will offer you the ability to overfuel and underfuel during load fluctuations, and spill fuel into the surrounding environment, mix with local oxygen, and hang out until such time that a source of ignition reaches it and blows your shop to hell... and it'll save you about fifty bucks.
Here's some other notes:
Gas grille regulators accept tank pressure, and eminate about 11" w.c. output... but this is PRESSURE LIMITATION. Along a totally different path, They have very defined VOLUMETRIC limits... that means, although it may be passing a BUNCH of gas volume at 11" w.c., the diameter of the orfices IN the regulator will only pass so_much_fuel_gas... and when you exceed it's rating, there's a sliding valve in there called EXCESS FLOW valve which SLAMS SHUT, preventing any more fuel gas from escaping. This is a safety feature that keeps your gas grill from blowing you up if the burner's pot-metal gas valve corrodes in half, fills with water and freezes/cracks to pieces, or you've drilled out the hole because wasps plugged it with mud... and it also minimizes the mayhem caused when the flexible hose between regulator and burner is compromised.
When you run an engine that, on accellerating to governed speed, demands around 750,000btu/hr of fuel for a few seconds, from a gas grille valve that's rated for 40,000btu/hr, that 'excess flow' valve slams shut, and your engine stops.
So best to use an appropriately sized regulator at EVERY stage.
An acetylene regulator WILL work on propane (those fitted with internals specifically for it will have the best lifespan, of course)... but the acetylene regulator's flow volume is NOT very sensitive to a changing demand... fuel gas torches are static-flow- they don't have changing demand. They're also intended to work in the PSI range, which is SUBSTANTIALLY higher in pressure than Inches of Water Column... so in general, it's an incredibly lousy choice.
Now, in oilfield applications, it was NOT unusual for one of these engines to be fueled off a constant flow source... but typically, that source was 'well head gas'... that was not as likely to flow if the engine stopped running the pumpjack.
If you wanna do a casual test just to see if an engine will actually fire, then give it a try, but don't expect it to be effective, accurate, or even remotely safe to do it in real running.
Wisest to use the 'right' tool for the job. For most machines, the valve combinations I noted above are the best. IMPCO J or Cobra valves to go from full tank pressure liquid or gas down to the mixer, or a 'residential' size first stage regulator (tank down to either 10psi or 2psi), then to a 'residential size' second-stage regulator (from 10 or 2psi 'line' down to 11" w.c.), and then on to a Garretson KN, connected to the mixer.
The latter combination seems more complex... (two regulators+KN to mixer), it's certainly the best performer.
Oh, and remember- if you're using a gas grill tank, and it's getting really cold while you're fueling something, it's gonna start having difficulties under load, because the propane bottle is too cold to facilitate expansion of the liquid propane into gaseous state. Adding heat to the tank, or going to liquid withdrawl to a vaporizer/converter... or just switching to amuch, much larger tank will solve the problem.
---------- Post added at 10:47:38 PM ---------- Previous post was at 10:41:13 PM ----------
The difference in most of these, is wether it's got additional 'features' like manual or electric primer button, no primer button, inlet/outlet sizes, and other features.
IMO, a simple and basic machine that you'll be manually operating doesn't need additional stuff. Notice that the simple one is about $40?
The Following 4 Users Say Thank You to dkamp For This Post:
Old 12-12-2017, 10:52:48 AM
tyrion's Avatar
tyrion tyrion is offline
Images: 42
Very good and accurate info thank you dkamp!
Old 12-13-2017, 11:51:06 AM
Okay, so in answering Rex's question more directly:
I'm having network connection issues at this hotel, so I can't seem to get a closer look at the engine or mixer to acertain flow... so I'll base the following suggestion on the assumption that this engine is under about 10hp, and the mixer is an Impco CA100, or something generally similar in size and operation. In that case, it's in the same realm as my Fairbanks Morse ZC-118... 118ci, 500rpm single.
Mine is fitted with the following:
Impco CA-100 'clone' mixer... (mixes propane with incoming air) connected to
https://www.propanecarbs.com/garrets...regulator.html
Garretson KN demand regulator (039-122) with standard orfice ( meters propane based on mixer's demand) connected to
several feet of propane-suitable hose, some adapter fittings...
A two-stage regulator that is rated to pass your engine's fuel demand... and a couple adapters and a propane tank fitting.
Here's one possibility that SHOULD work:
https://www.amazon.com/Camco-59333-H.../dp/B0024E6TX2
See how it's rated to 160,000btu? If you were using it on a gas-grille application, it would flow enough fuel to easily run a 160,000btu burner... but if you asked it to flow MORE, it would either become very restrictive (meaning, it would no longer be able to accurately regulate) OR... the Excess Flow safety feature would overrun, shutting off flow altogether.
Now, as I noted above, you didn't give details of which engine, so I'm gonna guess that your engine will demand less than 160000btu, because that equates to 62 thermal 'horsepower'. In a reciprocating engine, efficiency is about 20%, so that means a 12.4hp engine will be taxing it pretty heavily.
The 'gotcha', is that the 160,000btu rating is when flow is CONSTANT. In a single-cylinder engine, the flow swings rapidly with intake events, so it may PEAK at substantially higher airflow, but for a much shorter duration than say a four or eight cylinder engine, and that's why these little singles can have such beastly large intakes. It's why the CA100 on my 6hp 118" oilfield engine works nicely on a 78hp 338ci Hercules JXLD inline six.
Fortunately, the dual stage here is inexpensive, and the bonus, is that it comes with a POL fitting to thread directly to your gas grille.
If you go this route, you'll need some brass plumbing fittings on the Garretson KN input (1/2" NPT IIRC), a few feet of propane-suitable hose, and another fitting from the dual-stage to the hose. Simple push-on bayonet type fittings and a pair of hose-clamps will work fine... and if it's under 10hp, you can get away with 1/2" hose ID as long as it's not more than three-four feet.
When you assemble the components, use gas-rated teflon pipe thread tape... but start at the second thread. I prefer to put teflon thread sealant on over the tape and second thread as well- it's a standard procedure for my gas suppliers, so I follow it with my own. It doesn't take monster torque to keep the seal- don't lean on it hard as it'll just crack up the castings. Your connections will all be at 11" w.c. or lower, so it won't take much force at all to seal your gas piping totally.
Safety note- although the Garretson KN will stop propane flow when the engine is not running, With no automatic lockoff, there's a possiblity that changes in atmospheric pressure, or even wind blowing over the stack of the engine, will cause it to flow fuel. In a liquid fuel comparison, if you leave the gasoline petcock on in a carbeurated engine, the liquid fuel in the float bowl will not only evaporate, changes in air pressure will occasionally cause the fuel to be pulled up from the bowl through main or idle jet into the venturi. (this is one of the reasons why carbeurators on old tractors that don't get run much wind up with empty tanks, crud and water accumulated in the carb and jets... the fuel leaves, the rest stays behind, and oftentimes, winds up in the manifold too...)
Because of this situation, ALWAYS turn off the fuel bottle when not running the engine. Aside from that, everything I've noted above is inexpensive and easy to figure out, and once in, turn on the propane bottle, throw the flywheel over, stand back and laugh as it thump thump thumps along.
---------- Post added at 09:51:06 AM ---------- Previous post was at 09:12:00 AM ----------
Oh... and a blanket caveat-
With respect to the dual-stage regulator, and including the propane tank... I'm basing my recommendation on the assumption that you're running the engine as a display, rather than a hard-working application. The difference being, that in a display environment, you won't be applying a load that demands lots of fuel. A little alternator or generator, mebbie a squirrel-cage fan on a belt, but nothing big. I'm also assuming that it'd be run on sunny, warm outdoor days. Propane in the tank is liquid in the bottom, gaseous vapor on the top. As you withdrawl gas from the top, liquid on the bottom evaporates. In order for the liquid to evaporate, it must expand, which means it needs to absorb heat in order to properly equalize. As this happens, the LIQUID, and the tank structure, get cold... it's drawing heat from the outside environment. IF you attempt to draw fuel out of a tank faster than ambient heat can equalize, the liquid chills so far that it won't evaporate, thus, your tank's internal pressure will fall rapidly, and there will be insufficient gaseous pressure to feed the engine. In this case, there are only two solutions- first, is go to a bigger tank... it has more internal surface area for evaporation, and second, it has more exterior surface and mass to absorb ambient heat. The second solution, is to change the fueling system over to a liquid propane delivery, where liquid propane is withdrawn from the tank, through a 'converter', which is a combination of regulators, evaporators, and sometimes even a demand regulator, so that very low tank pressure can still provide substantial fuel energy. The converter generally always has some method of acquiring lots of heat... like through a pair of hoses coming from the engine's liquid cooling jacket... or in the case of an air-cooled motor, the converter is either mounted in engine cooling airflow, or sometimes it's mounted to a hot spot in the engine via an aluminum bracket to conduct (by convection) a 'certain amount' heat from the engine to the converter. It's not uncommon to see machines like ride-on concrete trowels and large floor-scrubbers, ice-polishers, etc., set up like that...
And now... if you ever see a converter mounted on a bracket to an exhaust manifold or cylinder head, you'll know WHY it was done that way... and when someone moves it to some other mounting place, you know why the engine runs lousy in cold weather! ;-)
Old 12-15-2017, 05:10:57 PM
Images: 8
The IMPCO J is a combination dual-stage regulator/vaporizer/demand regulator... tank pressure on the input, and demand level output. :
Thanks for all the detailed info, I think this is what I'll do.
Old 01-13-2018, 07:37:08 PM
Images: 8
Just received a Century C-J B Converter. Description indicates it converts liquid propane to vapor, will it work since I'm supplying it with vapor from the BBQ grill tank?
FM ZC 208 Regulator for propane ClayMartin Carburetors, Mixers, Fuel Pumps and fuel delivery 1 09-29-2016 08:13:34 PM
Propane regulator GarysToys Scale Model Engineering 4 10-22-2011 02:21:18 PM
Propane Regulator setup help needed. Frankiec Generators & Electric Motors General Discussion 18 12-15-2009 10:29:14 PM
7.5JB Propane Regulator JBittnerSr Onan Generators 4 10-11-2007 08:18:45 AM
PROPANE REGULATOR H PRICE Antique Engine Archives 1 07-15-2000 01:02:36 PM
