Vintage Construction Equipment Graders, Shovels, Dozers & Crawlers, Pay loaders & Fork lifts
Buffalo Springfield Roller
this thread has 48 replies and has been viewed 4996 times
Old 02-14-2018, 03:36:27 AM
sdarmstrong sdarmstrong is offline
Default Re: Buffalo Springfield Roller
That would be great . Thanks .
Old 02-14-2018, 08:18:51 PM
Heins Heins is offline
Here are pictures of the engine tag of a UD-14 engine that is in a galion grader. Your engine tag may be on the side of the engine block. Here are two places you may try for your parts. You may tell them you have a UD-6 or M-D tractor engine.
www.steinertractor.com or www.yesterdaystractor.com
ID:	303186   Click image for larger version
Old 02-14-2018, 08:46:22 PM
Thanks for that . If Iím home from work tomorrow before dark I will try to find the tag .
Old 02-15-2018, 08:20:29 PM
Iím afraid all thatís left of my engine tag is a couple of rusty rivets . Tag is long gone .. the injector pump has a tag. Would that help trace the engine no / etc ?
Old 02-15-2018, 10:15:10 PM
I don't think the tag on the injection pump will help. I think if you talk to someone that sells engine parts, they would tell you if the TD-6, MD tractor engine, and UD-6 parts are the same.
  #26
Old 02-15-2018, 11:12:25 PM
ihredo4 ihredo4 is offline
Originally Posted by sdarmstrong View Post
Thatís very nice
---------- Post added at 02:29:27 PM ---------- Previous post was at 02:21:22 PM ----------
So got some numbers off mine this evening.
Numbers on the head are
9 23 M
8228DE
While number on the engine seems to be
8290D9
Would that make it an international D9 made in 1943?
Whatís the chance of getting a head gasket for one ? I donít know why it was stripped over 30 years ago . I guess frost crack might be a likely reason? Where would it be prone to crack ? Any info would be great. I guess I coukd really use a manual for the engine and the roller. Any ideas where I might look ? Also any photos of similar rollers would be good . Is there a register of these rollers on file anywhere? Iíd love to know how it got to this part of the world.
DID this head come off this engine or was it off when you got it? There is a discrepancy between the numbers you gave.
First the head:
9 23 M = SEPTEMBER 23 1943 Component Casting date.
8228DE = PU8 = U-6 & UD-6 Power Unit,
PU17 = IU-6 & IUD-6 Tractor-Engine-Over-Axle-Unit,
TC23 = T-6 & TD-6 Crawler Tractor,
TC28 = Farmall M, MV, MD and MDV Tractors,
TC33 = McCormick-Deering O-6, OS-6, W-6 and WD-6 Tractors,
TC34 = International I-6 and ID-6 Tractors.
With the third valve in the head on each cylinder it IS a diesel thus knocking out anything without a "D" in the description. the UD-6, IUD=6, TD-6, MD, MDV, WD-6 and ID-6 ALL use the same 6 designation or 248 Cubic Inch engine.
Second the number on the engine seems to be:
8290D9E of which 8290DBE is the nearest number I could get in my book.
So 8290DBE = PU-11 = U-9 & UD-9 Power Unit,
= TC-24 = T-9 & TD-9 Crawler Tractor,
= TC-32 = W-9, WR-9, WD-9 & WDR-9 Tractors,
= TC-35 = I-9 & ID-9 Tractors.
Again taking away anything short the "D" as they are not Diesels leaves you with UD-9, TD-9,WD-9, WDR-9 and ID-9. This would be a 9-series engine or 335 cubic inch's.
Per the numbers given this head will NOT fit the block. I got this info from my copy of the 19-XPC Index of Parts Numbers.
Old 02-15-2018, 11:52:20 PM
ihredo4, he said the bore is 3 7/8".
Old 02-16-2018, 03:51:35 AM
Is it possible the 9 engine has had sleeves fitted to suit a 6 head? This would be a pretty unusual engine over here so I really dont know what the chances of having a rogue head are . I will see over the weekend if the head fits the block I guess .
---------- Post added at 02:51:35 AM ---------- Previous post was at 02:44:58 AM ----------
I should also say the head was not on the engine when I got it . It came with a bucket of bits like the valves , injectors , springs etc . I guess someone could have picked up the 6 head . But the bore of the block is 3 and 7/8 which is a 6 not a 9.
Old 02-16-2018, 09:50:52 PM
True, I forgot that was mentioned but going by the numbers supplied I wanted to offer up what the Index of Part Numbers. He did mention the engine number seemed to be 8290D9. To my knowledge IH never ended a Part Number with a number. It was always an Alpha character. Anyhow my bad for not reviewing the complete thread.
---------- Post added at 07:50:52 PM ---------- Previous post was at 07:43:04 PM ----------
Not sure why anyone would sleeve a 9 engine to a 6 piston diameter but the block from a 9 is longer than a 6 anyway so its a moot point. Likely the number of the block that you wrote down was in error somehow. With the 19-XPC you cant cross-reference an engine component to part number so don't have a guess to the correct part number.
Old 02-17-2018, 12:17:28 PM
Off work today so had a better look at it . The number on the engine reads 8280DH .
The number on the head is 8228DE
The head is the correct length for the block . Sorry for the incorrect numbers .
Hope that clears up the confusion Iíve created and you can tell me what I actually have .
Old 02-17-2018, 05:34:57 PM
8228DE = PU-8 = U-6 & UD-6 Power Units,
= PU-17 = IU-6 & IUD-6 Tractor-Engine-Over-Axle-Unit,
= TC-23 = T-6 & TD-6 Crawler Tractor,
= TC-28 = Farmall M, MV, MD & MDV Tractors,
= TC-33 = O-6, OS-6, ODS-6, W-6 & WD-6 Tractors,
= TC-34 = I-6 & ID-6 Tractors.
The engine block should have a serial number hand stamped into a machined surface just below the head and behind the injection pump. Engine number would be stamped like this:
FDBKM######## = Farmall MD = TC-28,
FDBKVM######## = Farmall MDV = TC-28,
IDBKM######## = International ID-6 = TC-34,
IUDBKM######## = International IU-6 = PU-17,
OBKSM######## = McCormick ODS-6 = TC-33,
TDBKM######## = International TD-6 = TC-23,
UDBKM######## = International UD-6 = PU-8.
Hope this helps you out and if I can help anyone else just ask.
The Following 2 Users Say Thank You to ihredo4 For This Post:
  #32
Old 02-17-2018, 09:35:20 PM
I will check again for this number. Thanks .
The Following User Says Thank You to sdarmstrong For This Post:
  #33
Old 02-18-2018, 04:13:43 PM
So just to confirm , a manual for a u d 6 will suit my engine ? I didnít get to it today to check for the hand stamped serial no .
Also does anyone know the correct manual I should be looking for to suit the roller itself ?
Old 02-18-2018, 05:58:09 PM
John Newman, Jr.'s Avatar
ihredo4
Ref: Post #26
"...With the third valve in the head on each cylinder..."
I do not see a third valve in each cylinder. Remember this is a gas start - Diesel run engine. There will be a spark plug hole (probably the one on top) and the injector hole (probably the one on the bottom) along with the intake and exhaust valves for each cylinder.
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
Old 02-18-2018, 06:31:03 PM
The valves seats are in the head . I also have the valves and one of the spark plugs is in the head itself .
Old 02-18-2018, 11:37:18 PM
Originally Posted by John Newman, Jr. View Post
ihredo4
Ref: Post #26
The third valve opens to decrease cylinder pressure for starting on gas. The lever on the left side of a gas start diesel engines dash board not only decompresses the engine but opens a butterfly on the gas start system to allow the small carb on the right to feed the engine. It also opens the ground so the mag or distributor can be operational. I'm sure the lever does some other items as well be haven't looked at them in a few years.
---------- Post added at 09:37:18 PM ---------- Previous post was at 09:10:33 PM ----------
The serial number on the block should give you the answer to this question. All SHOULD be the same but you just never know.
The Following User Says Thank You to ihredo4 For This Post:
  #37
Old 02-19-2018, 09:37:22 AM
ronm ronm is online now
ihredo4
Ref: Post #26
There is no spark plug hole into the combustion chamber. The spark plug is in a separate chamber opened up by the starting valve, & closed off when running on diesel. The smaller hole in the pic below the 2 valves is the starting valve seat. Slanted hole on top is the injector.
Smokstak member #442
  #38
Old 02-19-2018, 01:00:54 PM
Finally got the engine no !
UDBKM3941
---------- Post added at 12:00:54 PM ---------- Previous post was at 11:58:56 AM ----------
So thatís an international UD 6
Yes ?
Old 02-20-2018, 05:45:20 AM
You got it my friend. Your best bet for a parts manual would be the PU-8. Currently one for auction at:
https://bid.beckortauctions.com/view...alog/id/17405/
page 2 item # 176 for $10-12
the B suffix merely represents the second revision of the PU-8 manual.
Old 02-20-2018, 06:32:27 AM
Hi
Is the Pu 8 the same as the ud 6?
Buffalo Springfield useful hints for Buffalo Pitts Roller Engineers TractorDom Steam Stationary Engines, Traction Engines 1 11-23-2015 12:19:58 PM
Buffalo Springfield Steam Roller frogfoottrader Steam Stationary Engines, Traction Engines 15 04-25-2013 11:43:47 AM
Buffalo Springfield roller Bill Hazzard Steam Stationary Engines, Traction Engines 0 10-08-2012 09:57:30 AM
Buffalo-Springfield 5 ton Roller Peter Steam Stationary Engines, Traction Engines 36 09-12-2008 04:41:23 PM
Buffalo-Springfield Roller Mike in NC Steam Stationary Engines, Traction Engines 0 02-02-2005 12:17:03 AM
