Vintage Construction Equipment Graders, Shovels, Dozers & Crawlers, Pay loaders & Fork lifts
Towmotor Model 540 G truck
this thread has 28 replies and has been viewed 1482 times
Old 02-10-2019, 08:51:03 PM
gerald m gerald m is offline
Default Towmotor Model 540 G truck
I have a towmotor model 540 , sn 540600134 ,type G truck , spec# 111 . Have had this 6000 lb.lift for some time , used it for transferring barrels of spray foam , only use it a bit now but my issue although it starts and runs fine is that it burns oil so bad , even outside it just is to much. The engine just runs and works great if i keep the plugs clean . Originally it ran on gasoline then was swapped to propane, then back to gasoline ,and again after sourcing parts to rebuild propane system is now back on propane which i like for inside . My problem is i cant seem to get a positive as to what this engine is , all i know is its a 6 cyl. Flathead , valve and block engine with the distributor coming out the top between #4 and #5 cylinders . I have a few pics. That i will try to post . I have searched around but cant find info i am looking for . Any help would be great . Thankyou.
Old 02-10-2019, 09:46:59 PM
Default Re: Towmotor Model 540 G truck
It is a F600series Continental. By changing the bore size the displacement changed. One of the more popular ones was the F-226 engine.
Old 02-10-2019, 10:00:03 PM
Ok so i can use those numbers to source parts then hey. Do you have the name of a good parts place in north america . Or is cat the best place . Thanks for the info
Old 02-10-2019, 11:48:23 PM
Heins Heins is offline
I wouldn't go to Cat for parts, I would go to NAPA. First you should find out what engine it is, the Continental 226 is pretty common engine. It should have a tag I think on the side of the block.
Old 02-11-2019, 10:22:32 AM
Ok. Thankyou, john and heins , i will pull the bugger out and see what comes of it . Im sure i will be back for a bit of info.
ID:	328408   Click image for larger version
ID:	328409   Click image for larger version
ID:	328410   Click image for larger version
ID:	328411   Click image for larger version
ID:	328412   Click image for larger version
Old 02-11-2019, 01:13:36 PM
On the side of the block where you put the oil in there is normally a tag which has the engine model on it.
Old 02-11-2019, 05:02:45 PM
Sonny Reese Sonny Reese is offline
We had combines, cornpickers, and other farm equipment that used that F226 engine. they were very popular and a good engine! thanks; sonny
Old 02-11-2019, 08:27:51 PM
Here are pictures of a Continental 226 engine and the engine tag.
ID:	328464   Click image for larger version
Old 02-27-2019, 09:48:51 PM
A few more pics. as i go but still no tags . The one pic is of my last project
ID:	329607   Click image for larger version
ID:	329608   Click image for larger version
ID:	329609   Click image for larger version
ID:	329613   Click image for larger version
ID:	329614   Click image for larger version
Name:	Snapshot 2 (8-29-2014 11-41 PM).png
Old 02-28-2019, 12:13:37 AM
OnanParts's Avatar
OnanParts OnanParts is offline
Clean crud from area indicated. That appears to be the tag hiding underneath.
https://www.onanparts.com
The Following User Says Thank You to OnanParts For This Post:
Old 02-28-2019, 04:27:29 PM
Yup thats a flat spot on casting but i dont think it is a actual tag .but am heading to shop now . Thanks for your time onanparts
Old 03-08-2019, 02:48:37 PM
This is what i have found , no tags , without my calipers the pistons are 30thou. Over and with tape measure out to 3,3/16 inches. Haven't checked stroke length yet . Oil actually ran out of intake , cylinders seem very smooth , no ring marks or scoring . There is a bit of a ring ridge not bad though, maybe just a set of rings and some valve work .. Next i guess pull engine and open it up to check pistons .cant believe how nice it ran .
ID:	330191   Click image for larger version
ID:	330192   Click image for larger version
ID:	330193   Click image for larger version
ID:	330194   Click image for larger version
Old 03-11-2019, 08:45:56 PM
Ok. On pistons the top ring had no dots or taper . Second had both a dot and taper , both were installed facing down . Third was installed with taper down but had the oil ring back up . The oil ring was installed without back up which i think would explain the huge oil consumption . Rod brg. Were ok , wrist pins are nice . Pistons are 30 over rods are also 30 over . I think with ring ridge removed , glaze taken off cyl. Walls , new rings and rod brg. With gasket set should set o it . Pistons show very little wear . Any input is appreciated . Still not a hint of engine numbers .
ID:	330471   Click image for larger version
ID:	330472   Click image for larger version
ID:	330473   Click image for larger version
ID:	330474   Click image for larger version
ID:	330475   Click image for larger version
ID:	330476   Click image for larger version
Old 03-11-2019, 09:31:48 PM
The second ring should have the dot and taper up. I'm not sure about the third ring, maybe the taper down. The oil ring is a three piece, the ends of the thin rings should be 90 degrees from the gap of the center ring and 180 degrees from each other.
Old 03-11-2019, 10:00:29 PM
Yes but is that back up ring shown in second pic not for the oil ring,
Old 03-11-2019, 10:55:39 PM
Are you talking about the third ring in the second picture from the left? That should go under the third ring. That ring looks like an oil ring.
Old 03-12-2019, 02:55:18 PM
Yes the 7 sided piece. I thought hat was a backup for the oil ring. It was behind the third ring
Old 03-12-2019, 03:38:46 PM
The Continental F 226 engine has a 3 5/16" bore and 4 3/8" stroke.
Old 03-12-2019, 09:30:52 PM
Finally have found some numbers just above oil pan on valve side. Some of the casting numbers are as follows. f 209A405S. B13U there is a 7 right at the front that has been stamped in . The numbers where 209 and 405 are have been ground off and stamped with these numbers i think you can tell in the pics . Like i mentioned pistons are 30 thou over and measure 3 3/16 .
ID:	330526   Click image for larger version
ID:	330527   Click image for larger version
ID:	330528   Click image for larger version
ID:	330529   Click image for larger version
ID:	330530   Click image for larger version
Old 03-12-2019, 10:39:16 PM
What does the bore measure?
Need radiator for Towmotor lift truck Sccars1949 Farm Antiques and Collectibles 6 02-11-2019 08:08:27 AM
Old Towmotor Forklift Fred Prichard Lifting and Loading 14 07-09-2018 05:09:21 PM
Towmotor Forklift Help Jason Atwell Smokstak Down Under 10 06-28-2018 02:41:21 PM
Towmotor 350 Barry Barnhart Lifting and Loading 1 01-03-2018 03:15:39 AM
towmotor generator clifton clowers Generators & Electric Motors General Discussion 2 11-02-2003 07:19:46 PM
