Vintage Construction Equipment Graders, Shovels, Dozers & Crawlers, Pay loaders & Fork lifts
Towmotor Model 540 G truck
this thread has 28 replies and has been viewed 1481 times
Old 03-13-2019, 12:05:48 AM
gerald m gerald m is offline
Default Re: Towmotor Model 540 G truck
Bore seems to be 3 7/32.So it must be the 209 bored out to 226 specs. ?? So should just need a kit for the 226 instead of chasing 209 30 over kit or is my head soft.
Old 03-13-2019, 12:08:47 PM
Heins Heins is offline
A Continental F209 + .030 over =.2175
F226 =.3125
I think you have a 209
Old 03-13-2019, 06:43:16 PM
Ok, thank you Heins for all your help. I will check for parts availability. And post a bit as i go .
The Following User Says Thank You to gerald m For This Post:
  #24
Old 03-26-2019, 08:23:59 PM
Does anyone know of a parts supplier for the f209 continental . I can find places that can supply some of the parts but not all at one store. I did find out that the rod brgs. Are a split set . Thanks
Old 03-26-2019, 10:58:50 PM
NAPA should be able to get them.
Old 03-27-2019, 12:05:18 AM
Tried napa he says no , he tried his jobber and he can only supply rod brgs. @ 50 bucks per rod. Ill keep searching , maybe will need to buy from different suppliers . The rod brgs are not bad and can be used just thought it would be nice . Its the 4 ring per piston that seems to be a bit difficult to find . They must be odd somehow . Im sure this engine has been bored and sleeved , i can see the edge of the sleeve from the bottom .
Old 04-28-2019, 09:12:09 PM
finally got parts sourced and ordered,maybe another week and stuff should be here. be nice to get the old lift running again.
Old 07-04-2019, 10:21:40 PM
Done deal . rebuild went good , no glitches just a lot of time fixing things that have been neglected over time . smoked lots when first started but after maybe 1 hour of run time letting it cool completely between starts . now exhaust is clear and engine runs and sounds great . thank-you everyone , its a pleasure being a member . i will take a short video of the old boy running.
Old 07-16-2019, 12:39:53 PM
https://youtu.be/Rer5J2HPSIw all finished the old boy runs great. thank-you
Need radiator for Towmotor lift truck Sccars1949 Farm Antiques and Collectibles 6 02-11-2019 08:08:27 AM
Old Towmotor Forklift Fred Prichard Lifting and Loading 14 07-09-2018 05:09:21 PM
Towmotor Forklift Help Jason Atwell Smokstak Down Under 10 06-28-2018 02:41:21 PM
Towmotor 350 Barry Barnhart Lifting and Loading 1 01-03-2018 03:15:39 AM
towmotor generator clifton clowers Generators & Electric Motors General Discussion 2 11-02-2003 07:19:46 PM
