Vintage Construction Equipment Graders, Shovels, Dozers & Crawlers, Pay loaders & Fork lifts
Manifold Repair - IR 3R-36 Air Compressor
this thread has 2 replies and has been viewed 217 times
Old 07-01-2019, 04:08:01 PM
Question Manifold Repair - IR 3R-36 Air Compressor
Stupid woman driver decided she could fit behind me in a line of traffic. Only problem - my trailer was already in that space! She hit it so hard, she nearly knocked my 3R-36 off the deck. As it was, the compressor was knocked over on its side. as a result, the trailer frame rail got between the fuel tank and the air intake manifold, flattening the 3/4" copper runner. My question is: Does anyone make something that can open that runner back up? Doesn't have to be pretty, just functional, as most of the runner is hidden by the tank. i was thinking of possibly heating and forcing a series of steel balls thru the copper, the problem is that the top of the runner that is squashed is brazed to a common manifold. The tube is not full bore at that point, so driving the balls back out may be a problem. Any ideas??? Anybody know of a shop that does this kind of work> Thanks in advance,
Old 07-01-2019, 04:31:17 PM
dalmatiangirl61 dalmatiangirl61 is online now
Default Re: manifold repair - IR 3R-36 air compressor
Brass horn (trumpet coronet etc) repair guys fix dented tubes, probably some youtube vids on how its done.
If you can plug ends of pipe this looks pretty trick!
https://www.youtube.com/watch?v=UYXNp9mQR6o
Tuba repair, looks a lot harder than link above
https://www.youtube.com/watch?v=wflildRmcJw
Shotgun barrel dent removal
https://www.youtube.com/watch?v=DJyegZQ8F50
Tutorial on building the shotgun barrel dent remover, make it any size you need!
https://www.youtube.com/watch?v=FFUXJRcqnnA
Old 07-01-2019, 04:41:25 PM
Tracy T Tracy T is offline
a few pictures of your problem area would aid in a cure.
MD 22-36 Manifold Repair Russ Hamm Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 15 08-23-2018 02:35:45 PM
Recommendations for Manifold Repair old fashioned farmer Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 10 08-22-2018 09:55:29 PM
Manifold Repair Langes Machine Shop Welding Shop 4 10-23-2016 08:58:55 PM
Repair on cast intake manifold robert d Welding Shop 4 03-07-2009 07:10:21 PM
Manifold Repair Chuck Kaufman Hit & Miss Gas Engine Discussion 12 02-08-2005 10:22:47 AM
