Vintage Construction Equipment Graders, Shovels, Dozers & Crawlers, Pay loaders & Fork lifts
International t-6 piston swap.
this thread has 1 replies and has been viewed 168 times
Old 08-29-2019, 12:35:10 AM
Jeff Taylor Jeff Taylor is offline
Default International t-6 piston swap.
I have a 1940 IH t-6, it is the Kerosene/distillate burning version with low compression. I have found a set of high altitude pistons and sleeves but for the gasoline version(higher compression). I live in Denver so I believe these will help. But will I hurt anything putting them in my engine?
As far as I can tell the only difference between the Kerosene and gas tractors is the exhaust manifold.
Old 08-29-2019, 08:55:55 AM
PFT's Avatar
PFT PFT is offline
Default Re: International t-6 piston swap.
They will work just fine, they are made for mountain locations. People in the low lands use them to get a little more power out of the old machines.
PT
51st Annual Piston Powered Auto-Rama "Piston Power Show" marion7200 Shows and Swap Meets 1 01-27-2017 09:01:01 AM
International Engine Piston Water Pump Parts ID. Please. ShaneZahn Unidentified Engines 2 01-06-2013 01:50:17 PM
47mm Stihl S10 piston swap question PistonRing Chain Saw Collectors 1 11-04-2011 06:00:40 PM
Piston Ring Material for Custom Machined Piston Rings. Uncle Old Iron Hit & Miss Gas Engine Discussion 3 06-24-2007 01:50:53 AM
Piston pump - - piston cup material options ? Pete LaBelle Steam Stationary Engines, Traction Engines 6 05-18-2006 10:54:18 PM
