Can you identify this part? 6.5 NH 3CE
this thread has 2 replies and has been viewed 331 times
Old 02-07-2018, 08:00:35 AM
DrMikeVB DrMikeVB is offline
Default Can you identify this part? 6.5 NH 3CE
Can someone tell me what the control box with springs attached to the governed is? Does it require service or adjustment?
If so can you provide instructions?
Thank you
Old 02-07-2018, 08:25:11 AM
Billy J Shafer's Avatar
Default Re: Can you identify this part? 6.5 NH 3CE
That is the vacuum booster. Run the engine and run the slide to where is no tension on the spring. Then put a full load on the engine. The booster arm should then pull on the throttle. To keep the speed up.
Old 02-07-2018, 08:26:38 AM
MBB MBB is offline
Its a vacuum speed booster. Check out this thread for an explanation. Post#6. It isnt your model but information applies the same.
https://www.smokstak.com/forum/showthread.php?t=104235
The Following 4 Users Say Thank You to MBB For This Post:
Can anyone identify this part Geochurchi Farm + Industrial Antiques and Collectibles 6 09-22-2014 07:02:59 PM
Can anyone identify this part? Jim Sears Antique Farm Tractors 5 09-08-2014 11:51:23 PM
Help Identify This Part rp56 Farm + Industrial Antiques and Collectibles 3 05-31-2013 05:59:30 PM
Can you identify this part / what's this for? Luke Tonneberger Antique Gas Engine Discussion 7 06-07-2010 07:49:57 AM
help identify part Charles McDuffee Antique Engine Archives 6 10-23-2004 02:53:53 AM
