Onan 7.5JB Wiring Diagram
this thread has 22 replies and has been viewed 5223 times
Old 11-02-2011, 04:02:54 PM
bobbyz72 bobbyz72 is offline
Default Re: Onan 7.5JB wiring diagram
Mine is not wired to any onan wire diagram. All mine has is a push botton switch that operates the starter. And an off on switch that controls (+) to the ignition relay and ignition coil, a low oil pressure switch, and hi temp switch. And another switch to switch between points-off-electonic ignition. Mine is wired very simple.
Old 11-02-2011, 04:16:37 PM
goaliedad30 goaliedad30 is offline
bobbyz72,
I assume your simple system works, what are the pros and cons of what you have? Would you recommend doing it that way?
Old 11-02-2011, 06:52:55 PM
I have manual #967-500 that covers the JC & JB with magniciter gen-ends if you would like to have it.
The Following User Says Thank You to Max Thompson For This Post:
Old 11-02-2011, 07:32:22 PM
Max,
Anything you have that you think would help would be greatly appreciated. How would I go about getting it?
Old 11-02-2011, 08:14:53 PM
Cons, no battery charging, no remote start up.
Pros, super simple, you can work on it at 1am with only 1 eye open. Walmart battery maintaner keeps battery full 24/7
Old 11-03-2011, 07:43:33 AM
Originally Posted by goaliedad30 View Post
Max,
Post or PM an e-mail address & one of us will send it out.
The Following 2 Users Say Thank You to Max Thompson For This Post:
Old 11-03-2011, 09:11:54 AM
Email is simonwhittaker@sbcglobal.net . Thanks very much for your help!
Old 11-03-2011, 12:32:51 PM
Should be in your in-box.
Old 11-03-2011, 12:55:30 PM
I think I may have what I need, thanks to everyone who helped!
Old 02-06-2018, 12:39:04 PM
Farris Farris is offline
i dont know if you are still around but i sure could use the manual you have with the jb generator end wiring diagram. thanks a thousand times if you can send to me at farrisbrown@gmail.com
i sure could use the jb wiring diagram on the generator end if available. farrisbrown@gmail.com. a thousand thanks
Onan 12.5JC wiring diagram djackman Onan Generators 28 07-18-2017 01:45:36 PM
Onan 15.0JC-4XR wiring diagram krc002 Onan Generators 9 03-20-2014 04:05:07 PM
Onan CCK Wiring Diagram BTPost Onan Generators 9 07-08-2012 12:21:40 PM
Onan 5go wiring diagram TomFG Onan Generators 0 02-23-2010 11:34:43 AM
wiring diagram Onan W2C werfymmot Onan Generators 15 10-31-2004 04:04:54 PM
