Piston Clearance Advice
this thread has 20 replies and has been viewed 1778 times
Old 12-03-2017, 10:34:10 AM
G.M.Johnson G.M.Johnson is offline
Default Re: Piston Clearance Advice
I would absolutely get in touch with your friend who bored and sleeved the engine. You didn't make the mistake, he did. Being a friend of course just approach him about it easily. Was probably a simple brain fart on his part. It happens to all of us.
The Following User Says Thank You to G.M.Johnson For This Post:
Old 12-03-2017, 11:46:02 AM
KeithW's Avatar
KeithW KeithW is offline
If I did a job for a friend and it turned out wrong I would want to know so I could make it right.
The Following 3 Users Say Thank You to KeithW For This Post:
Old 12-03-2017, 02:10:37 PM
akuna akuna is offline
Get in touch with him and say hay, I think I made a mistake on that cylinder you sleeved for me. The piston is too loose. Can you fix it for me?
See what he says.
Worst it would cost you is a new sleeve. Unless an oversized piston is less cost to fit?
Old 12-03-2017, 03:08:12 PM
SteveK SteveK is offline
I just might I guess. I gave him the piston when he put the sleeve in so he could get everything correct.... It will be a spell however, he is in Florida for the winter.
I will see what a piston would cost in the mean time.
On the level
Old 12-03-2017, 08:06:38 PM
Vinny Cavaliere's Avatar
Vinny Cavaliere Vinny Cavaliere is offline
Yes the piston to cylinder clearance is too much. However a new set of rings with a tighter inside dia. on the ring to the piston should solve the problem. A really good place to make rings is in Cleveland Ohio.
Vinny
Old 12-03-2017, 08:13:59 PM
AngrySailor AngrySailor is offline
Good God man! That's crazy talk! Not trying to be a dick but no... the ID of the ring cannot touch the OD of the ring land or be used to take up clearance. Doesn't work that way.
Old 12-03-2017, 08:48:20 PM
Charley K Charley K is offline
Well I also hate to be a.... See my previous post. There are only two ways to fix this. New liner or larger piston. Hone to specs. CK
Old 03-11-2018, 09:43:57 PM
Here is an update on this engine. While I had the piston and rod out I took the wrist pin out and looked at it and the bushing. The pin was quite worn and the bushing as well. Very loose. So I made a new wrist pin and pressed in a new bushing then reamed the bushing until the pin just fit. Then I drilled the oil hole and cut some oil grooves in the bushing. While the piston was loose I slid it in the bore and once the whole piston is in the bore I cant wiggle it, only when the skirt is out of the bore at BDC can I move the piston up and down.
So I re assembled everything and fired it up, NO NOISE Nice and quiet.
I don,t have a bore gauge just telescoping gauges so I am guessing I probably gave an inaccurate measurement on the bore size, also the only thing I had to measure the piston diameter with is calipers. SO either my measurements were wrong and the fit was not sloppy or it is sloppy but not what was making noise. I guess I'll just run it. Thank for the comments at any rate.
On the level
The Following 3 Users Say Thank You to SteveK For This Post:
Old 03-12-2018, 01:51:52 AM
cobbadog cobbadog is offline
Glad you found a solution to your problem and that you can go out and make some noise for the neighbours.
Something I was going to suggest if it was possible was to machine another ring gland lower down the skirt of the piston like on some tractor pistons. That might have helped hold the skirt away from the bore.
Old 03-12-2018, 10:26:51 AM
ronm ronm is offline
And once again...
Smokstak member #442
Piston clearance bwommack Antique Gas Engine Discussion 10 11-01-2012 09:04:00 AM
Piston Clearance jopeter Smokstak Down Under 9 01-20-2011 06:28:46 PM
Piston Clearance lowboy Antique Gas Engine Discussion 1 07-06-2010 10:08:52 PM
Piston Clearance Red Bud Farms Antique Gas Engine Discussion 7 12-30-2009 09:10:45 PM
Piston Rod Material And Piston Clearance Dave S Steam Stationary Engines, Traction Engines, Steam Boats 11 05-26-2008 07:45:29 PM
