Unusual Brass Bearing
this thread has 4 replies and has been viewed 649 times
Old 04-07-2018, 10:40:45 AM
Default Unusual Brass Bearing
I started working on a machine called a Sample Grinder. The one gear was stuck tight in the bearing. After a couple of hours work the bearing came out with the gear. It is a split bearing with holes filled with graphite. I have never seen anything like this and would like to hear your comments about this. Ron
ID:	307539   Click image for larger version
The Following User Says Thank You to Ronald E. McClellan For This Post:
Old 04-07-2018, 11:25:26 AM
JoeCB JoeCB is offline
Default Re: Unusual Brass Bearing
I've seen bushings like that used on guide pins for die sets. Sliding motion , up and down not for rotation. Also, and this is just a guess from the color of the "brass" , it is in fact hard bronze, Al- Bz, not normal bearing material.. just a guess
Joe B
Old 04-07-2018, 03:11:49 PM
I've seen a few like that. The FM 208 clutch uses something similar.
Old 04-07-2018, 03:50:13 PM
ChipTosser ChipTosser is offline
We used them for die pin bushings and cam slide bearing surfaces.
They are intended to be used with oil only.
They are aluminum bronze base metal with graphite plugs to help retain oil.
As previously mentioned, not a high speed application. It could be used, if flooded with oil with plenty of clearance and the proper directional oil groves and scrapers to direct the oil.
---------- Post added at 03:50:13 PM ---------- Previous post was at 03:49:11 PM ----------
Oilies bearings
Old 04-07-2018, 04:23:01 PM
mcostello mcostello is offline
I have some setting around here, let me know if You are interested as they have set here for around 20 years and just were headed for the great recycler in the sky. Also some that are bronze tinted mixed with carbon.
Unusual Brass Apparatus...Carburetor? Jason Dahm Antique Gas Engine Discussion 0 04-03-2014 11:34:08 AM
OK to use broken rod bearing or chipped main bearing?? eagleeyelee65 Antique Gas Engine Discussion 19 09-30-2011 10:33:03 AM
Brass main bearing on Upright Magneto? enginesilo Maytag Engine Collectibles 4 05-15-2010 10:08:58 PM
Single bearing to 2 bearing conversion bill2455 Generators & Electric Motors General Discussion 5 02-15-2009 01:58:34 PM
Brass bearing tip: resizing with babbitt PaulGray Antique Gas Engine Discussion 1 06-13-2006 09:53:48 AM
