Onan CCKB starter motor
this thread has 5 replies and has been viewed 2516 times
Old 04-06-2012, 05:27:29 PM
marinoniblue marinoniblue is offline
Default Onan CCKB starter motor
I have a Gravely 450 which has an Onan CCKB. The engine is model: MS/1271G, serial number: 37C953779. The starter motor is: MBG 4134 B. It was starting but the starter motor was making some strange noises - so - I took it apart to clean it and stick some grease in various places. It has a bendix assembly not a solenoid. I put it all back together and now it runs backwards????? There are four brushes. Two of them are wired to the end cap and two of them are insulated from the end cap and wired to the field windings. I tried putting the end cap on rotated 180 degrees. Still ran backwards. then I tried rotating it 90 degrees. The wires are long enough to do that one way, still runs backwards, but not long enough to do the other way. I was going to rotate the end cap 180 and then try the 90 degree thing again but haven't tried that yet. Any thoughts? If I should just buy a new starter motor where would you suggest to look? Thanks - Marinoniblue
Old 04-06-2012, 06:08:08 PM
Ben Clarke Ben Clarke is offline
Default Re: Onan CCKB starter motor
Are the Positive and Negative leads supplying power to the started hooked up correctly? What happens if you reverse them. If it grounds through the starter body then look at the battery to be sure that the Positive and Negative are not reversed.
The Following User Says Thank You to Ben Clarke For This Post:
Old 04-06-2012, 10:01:53 PM
Ben - I forgot to mention it, but I did try reversing the leads, and it still runs backwards. The tractor is negitive ground. - Marinoniblue
Old 04-06-2012, 11:18:19 PM
pnora pnora is offline
Double check your brushes. Make sure the paired brush 180 opposites are wired together as a pair. Rotating the brush set does nothing.
Old 04-07-2012, 11:18:44 AM
Lloyd H Lloyd H is offline
Is the field permanent magnets or wire wound electromagnet? I'm guessing wound field coils since reversing the battery does not reverse the rotation. Either or you need to move the brushes 90 degrees if there are four brushes.
Old 04-08-2012, 04:28:17 AM
Flintstone Flintstone is offline
I remember some deal from years ago, polarizing the armature...is there some chance he zapped it to favor backwards? I'm a bit rusty there, might have been in 6th grade! (in the Northern hemisphere).
Onan JB Starter Motor Problem Leon N. Onan Generators 13 11-07-2011 11:09:29 AM
Onan CCKB 4r/1b info joshlaurin79 Onan Generators 13 05-28-2010 07:55:31 AM
Onan CCKB? 1800rpm? wyM1Aguy Onan Generators 18 02-16-2010 08:51:20 AM
onan cckb need help ponyofky Onan Generators 1 12-31-2006 01:44:18 PM
Onan Cckb peter yung Onan Generators 6 05-31-2006 12:34:06 AM
