ST Head on my Onan MDJE Motor
this thread has 10 replies and has been viewed 1533 times
Old 12-07-2012, 04:54:52 PM
Graycenphil Graycenphil is offline
Default ST Head on my Onan MDJE Motor
So my MDJE generator head is dead (discusssed in another thread) but the motor is great. At the suggestion of a few folks, I am considering connecting an ST head to the Onan engine. (Will I have to move the thread out of the Onan Generators forum? Will old DW haunt me?)
I believe it is as simple a smatter as mounting the head on a frame next to the end of the engine, then connecting it with something like a Lovejoy. Start the engine, and electricity coemes out of the ST. Is that right?
ant issues to be aware of? Will it be good, stable, clean electricity?
Thanks.
Old 12-07-2012, 05:08:58 PM
Default Re: ST Head on my MDJE Motor
My experience with ST generators is that they make electricity, which beats not having any by a large margin. So in that context it is "good" electricity.
If the other two adjectives are critical, consider a Marathon, Winco or similar generator end. Not inexpensive, but far ahead of the ST in quality and capability. The Winco 8KS2GC-3 might be a good match.
---------- Post added at 03:08 PM ---------- Previous post was at 03:06 PM ----------
That Winco turns at 3600, so scratch that one...
Old 12-07-2012, 08:54:25 PM
That was my problem - there are so few 1800 rpm gneerator heads sold.
I imagine the frequency will be pretty stable because it is a product of the Onan governor. But what will be inferior about the ST electricity? Does the voltage vary a lot?
How exactly does it regulate the voltage? I believe the Onan AVR varies the field current according to the AC voltage it senses? How is the ST doing it?
Old 12-07-2012, 09:18:54 PM
scoops scoops is offline
See here
http://www.utterpower.com/voltage-excitation/
And here
http://www.utterpower.com/ST.htm
The Following User Says Thank You to scoops For This Post:
Old 12-07-2012, 11:02:05 PM
BigBlockChev's Avatar
If you really need to use a 3600rpm generator head with your Onan engine you can always use a 2/1 belt drive sheave setup. You are going to have to figure out how to connect the generator output shaft to some sort of coupling in any case as nothing will bolt on to the taper on the existing engine, Machining will be necessary.
Old 12-07-2012, 11:23:57 PM
If it were me, I'd save the rotor,
I keep the part that mates with the taper, have it cut put a key way in and a love joy on, and find a smaller length bolt.
Old 12-07-2012, 11:52:09 PM
moteurdelco moteurdelco is offline
rewind the exciter field ,the other parts are ok if you were having 45 vac without excitation. bearing 6205 is cheap to buy.
Old 12-08-2012, 07:50:16 AM
One of those Lovejoy connectors won't attach to the engine shaft?
I suppose I could do that. Same question as above - the Lovejoy won't attach to the shaft directly?
I wouldn't mind doing that, but everything else sure is rusty and corroded. And I can't say I didn't do some damage taking everything apart.
Old 12-08-2012, 09:17:11 AM
Default Re: ST Head on my Onan MDJE Motor
The taper is specific to onan.
I'm sure one of the experts here probably knows the taper size,
I've never seen a taperered love joy.
Keep you rotor shaft, a machinist could easily make you what you need
Old 12-08-2012, 10:00:36 AM
Why not just look for an Onan generator end? xJB, xJC ends are not that hard to find, and should "bolt on ". I have a 12.5kw single phase YD end that is probably good, and almost certainly less corroded than the one you have, but shipping would kill the deal.
Why not post an ad on the classified part of this site, you may get one lots closer. http://www.enginads.com/classifieds/showcat.php/cat/35
MDJE Head Gasket airbatica Onan Generators 1 11-01-2010 12:45:30 PM
MDJE Head temps at cut out switch FLracer Onan Generators 4 08-29-2010 02:24:47 AM
Onan MDJE - blows Blue smoke after replacing Head Gasket robertinmaine Onan Generators 6 08-25-2010 12:55:52 PM
Onan MDJE 6-7.5KW Help Mainshiptom Onan Generators 4 04-19-2010 05:32:50 PM
I think this is a T-Head motor? 61sprite Antique Gas Engine Discussion 15 10-18-2008 06:46:46 PM
