Onan 15.RJC ring gear part #
this thread has 8 replies and has been viewed 3043 times
Old 02-04-2011, 07:59:03 AM
tlhigham tlhigham is offline
Default Onan 15.RJC ring gear part #
Hello,was wondering if anyone may know the part # for a replacement ring gear,or complete flywheel?
Old 02-04-2011, 01:15:31 PM
Richard L Richard L is offline
Default Re: Onan 15.RJC ring gear part #
You should be able to take the inside and outside diameter of the ring gear and the no of teeth to a automotive machine shop and find one. Once you have you can heat the old one and it will drive off then heat the new one up in the Brides oven and you can tap it on the flywheel.
R
The Following User Says Thank You to Richard L For This Post:
Old 02-04-2011, 02:32:13 PM
BTPost's Avatar
BTPost BTPost is offline
Images: 1
Talking Re: Onan 15.RJC ring gear part #
Flywheel Onan #104-0547
Ring Gear Onan #104-0423
From Onan RJC Parts Book #974-0220 Spec A- AC issued 3-90
Page 14
Bruce in alaska
The Following 2 Users Say Thank You to BTPost For This Post:
Old 02-04-2011, 05:21:35 PM
It looks like the ring gears are the same for DJC<MDJC<MDJE,
Should be easy to find a flywheel for any of these and pull the gear
Old 02-04-2011, 10:06:24 PM
lijobi lijobi is offline
I can hook him up, I have many MDJ parts in the garage. It's a sickness I tell you!
Old 02-04-2011, 10:11:37 PM
BTPost's Avatar
Images: 1
I suspect that ALL the external starter J Series flywheels & ring gears will be the SAME..... xxJB/Es, xxJC/Fs....
Bruce in alaska
Old 02-04-2011, 11:40:35 PM
Lloyd H Lloyd H is offline
Easy way to heat ring gears:
Take the transformer out of a full size microwave and
cut the core apart as in "transformer-core.jpg" then
remove the the secondary coils and the two shunts.
Connect the cord to the primary coil, lay ring in one
core window and place the removed core piece back on.
plug in to 120 Volts and wait till ring gear is as hot
as you want. Don't take long and its heated evenly all
the way around. Lloyd H
The Following 3 Users Say Thank You to Lloyd H For This Post:
Old 02-05-2011, 12:52:34 AM
bbuchorn bbuchorn is offline
My ring gear was worn pretty bad on my MDJF. I found a new starter bendix on line and rebuilt my starter then tapped my ring gear off the flywheel, turned it over then heated it up with a torch and tapped it right back on again . So far it works perfect. Working on the unused part of the ring gear.
Worked for me.
The Following User Says Thank You to bbuchorn For This Post:
Old 02-05-2011, 10:14:33 AM
Old Style Old Style is offline
Worked for me.
That's a good option to know about! Thanks!!
CCK MS Ring Gear Steveb05 Onan Generators 4 07-15-2010 09:29:57 AM
No holes on crackshaft gear for puller ring on Onan CCKA dudditz Onan Generators 6 03-07-2010 11:10:34 AM
Onan ring gear bdbowtie Onan Generators 5 05-25-2009 11:17:47 AM
Tecumseh Ring Gear Frank Douglas Small Air Cooled Gasoline Engines 3 02-26-2008 08:10:25 PM
Ring Gear OT Mike Inglis Antique Gas Engine Discussion 3 06-06-2006 11:46:03 PM
