Hot Air Engines
Sterling Engine Repair
this thread has 1 replies and has been viewed 187 times
Old 07-11-2018, 07:08:14 PM
Sprintcars11 Sprintcars11 is offline
Default Sterling Engine Repair
Hello All,
I am trying to repair a model sterling engine. I need some flexible plastic tubing to join the connecting rods for both the displacer piston and the power piston together. I need tubing with an ID of 0.020in or 0.5mm. I only need like 6 inches to account for trial and error. Can anyone help?
Thank you!
Joe
Old 07-12-2018, 09:35:01 AM
Default Re: Sterling Engine Repair
Originally Posted by Sprintcars11 View Post
Hello All,
Thank you!
Joe
McMaster-Carr part number 5335K12 is 0.022" i.d. teflon tubing.
https://www.mcmaster.com/#5335k12/=1doig0z
If the tubing is located where it doesn't see much heat, you could slide the insulation off of a strand of telephone wire or any other small gauge wire you might have lying around.
Kirk
Sterling Engine Gary Bahre Hot Air Engines 3 05-11-2013 11:55:18 AM
Sterling engine kits CaptainJohn Scale Model Engineering 0 11-23-2007 12:45:25 PM
Sterling Engine??? Junkologist Small Air Cooled Gasoline Engines 4 06-11-2007 07:29:53 PM
Sterling engine almost done Tanner Remillard Antique Gas Engine Discussion 0 05-14-2007 11:21:09 PM
Charter Gas Engine Co. Sterling, ILL. Dusty M. Erickson Antique Engine Archives 1 02-16-2002 04:23:04 PM
