Stover Cam - Crank Reference Marks
this thread has 18 replies and has been viewed 1039 times
Old 07-11-2018, 05:22:50 PM
EMU EMU is offline
Cool Stover Cam - Crank Reference Marks
First Image shows what has been located so far , 2 reference marks .
On Cam Gear .
Name:	timing marks 5.jpg
Old 07-11-2018, 05:30:14 PM
EMU EMU is offline
Cool Re: Stover Cam - Crank ref marks
Second Image shows Crank Gear , The Mark where it lines up with centre of the Governor Weight , a touch out of line with Serial Number on Flywheel , also showing Crankshaft throw position , key way is ' not ' in line in the position shown . I have just provided this detail in this image to provide info . Of what has been found . Noticed . In this position No Marks Mesh together it is only to dhow what has been found .
The positioning of these ref marks , provided is showing far more information , that just alignments noticed . The Key way is not pointing up , nor in alignment , in this position , Key way is positioned to the immediate 'right' perfectly horizontal . Crank throw half way . Vertical . Serial number on flywheel which has a mark inner further not quite in alignment .
No attempt has been made to adjust Timing on Exhaust via the Cam Gear , or Rod .
The positioning of Serial number and what looks to be V on inner face of flywheel is also playing a role in planetary gear alignment .
Name:	Stover marks 2.jpg
Old 07-11-2018, 05:45:03 PM
EMU EMU is offline
Would there be any more .? Reference marks .
Only ' 1 ' of these ' 2 ' reference marks lines up , or attempts to mesh with both the Cam and Crank Gears , and that is for when Just as the Webster Magneto Trips just before TDC , I assume . Ignition reference .
I understand by Power of the Past Vol 3 detail , that ex valve timing is performed 1st and then 2nd Ignition Timing .
Could I assume that the reference marks for the Ignition Timing were the '' last settings '' made on the cam gear . ? As the mark references no longer mesh , for the Cam Gear Exhaust settings which has been moved to Ignition timing which shows as last settings made . ?
THIS IMAGE SHOWS WHAT I ASSUME TO BE IGNITION MARKS ATTEMPTING TO MESH . WHICH IN THIS POSITION IS JUST AS MAGGIE HAS TRIPPED .
I ASSUME THAT EACH TOOTH ON CAM GEAR CAN BE IN REF AS DEGREES .
IMAGE SHOWS WHAT IS ASSUMED AS SAY 10 DEGREES BEFORE TDC . ? Approx .
Name:	Stover marks 3.jpg
Old 07-11-2018, 06:14:19 PM
EMU EMU is offline
I am assuming the 2 mark ref on Cam Gear 1 is Ex and the other is Ignition .
Again the last setting made on this engine were Ignition .
---------- Post added at 07:55:47 AM ---------- Previous post was at 07:51:56 AM ----------
Does the Cam Gear need to be moved to set Ex Timing .?
Then obviously I assume the Cam Gear can be moved to set the Ignition Timing , which would show as the Last Settings shown .?
---------- Post added at 08:00:51 AM ---------- Previous post was at 07:55:47 AM ----------
---------- Post added at 08:07:58 AM ---------- Previous post was at 08:00:51 AM ----------
---------- Post added at 08:14:19 AM ---------- Previous post was at 08:07:58 AM ----------
Timing looks good . Not an expert , just a learner ……..
Old 07-11-2018, 08:04:05 PM
John Savot John Savot is offline
Default Re: Stover Cam - Crank ref marks
Looks like everything has been apart and painted. It is possible to put the cam gear on inside out or flipped over. If this is the case none of the marks will be in the proper relationship to the crankshaft gear. Somewhere on this site is a valve timing chart. Search valve timing.
John
The Following User Says Thank You to John Savot For This Post:
Old 07-11-2018, 10:29:38 PM
EMU EMU is offline
Can th
Can the Cam Gear have marks both sides .?
Old 07-12-2018, 06:56:38 AM
Default Re: Stover Cam - Crank Reference Marks
Have never seen the marks on both sides. The marks should be on the same side of both gears (outside).
John
Old 07-12-2018, 06:00:16 PM
EMU EMU is offline
Cool Re: Stover Cam - Crank Reference Marks
Correct marks on Cam - Crank Gears are only on 1 Face … That's what I have .
---------- Post added at 08:00:16 AM ---------- Previous post was at 07:57:29 AM ----------
Thinking there should only be 2 reference marks really as it is EX and Trip Timing . As stated earlier , the ref marks line up , or set last for trip ignition , timing , ex timing has already been performed , comprende
Old 07-12-2018, 06:07:29 PM
EMU EMU is offline
As can be seen alignments occurring , the mark being pointed to is the crank gear mark or ref , that eventually lines up with Trip Ignition approx. 10 deg BTDC . Although I have shown it here as aligned with governor weight centre , crank position half through , , serial number position on outer flywheel , ' gib ' key to the right horizontal .
Name:	timing mark 1.jpg
Old 07-12-2018, 10:31:19 PM
Tom Marshall Jr.'s Avatar
Images: 1
The timing marks are to set the cam so the valves open and close at the right time . they have nothing to do with the spark setting. you get the valves right then set timing to how much advance you want .
The Following User Says Thank You to Tom Marshall Jr. For This Post:
Stover cross reference?! Earpunch Antique Gas Engine Discussion 2 10-05-2016 11:36:50 AM
Stover engine timing marks fern Antique Engine Photos 7 03-02-2015 09:16:48 PM
IHC M timing crank with no marks a jossund Antique Gas Engine Discussion 5 02-13-2014 08:58:20 AM
ihc 3 hp crank/cam gear timing marks Dale Freidline Antique Gas Engine Discussion 2 10-09-2013 03:04:39 PM
Timing marks on john deere crank & cam Tim Beam Antique Gas Engine Discussion 2 03-05-2009 10:27:06 PM
