Onan CCK 5.0 compression
this thread has 4 replies and has been viewed 852 times
Old 10-27-2015, 07:30:25 PM
Surfinhurf Surfinhurf is offline
Default Onan CCK 5.0 compression
What should it be?
HURF
Old 10-27-2015, 07:44:23 PM
David C David C is offline
Default Re: cck 5.0 compression
105psi to 110psi with standard heads and 130psi to 135psi with high compression heads at ~500 cranking rpm per Onan service manual.
David
The Following 4 Users Say Thank You to David C For This Post:
Old 10-28-2015, 09:47:05 AM
Default Re: Onan CCK 5.0 compression
Thanks, The one I just picked up has 90 to 95. Both sides are equal. I haven't decarbed yet. Should be ok
Old 10-28-2015, 10:21:43 AM
Onan Dan's Avatar
Onan Dan Onan Dan is offline
Those CCK head gaskets are pretty tough I reuse them if they are no breaks in them clean up everything real nice and follow your service manual for sequence on the head bolts and torque ft lb.
The Following User Says Thank You to Onan Dan For This Post:
Old 10-28-2015, 02:44:05 PM
Motorhead's Avatar
I have not seen the high compression psi number ever on my 5.0cck. I have the high compression heads, good valve seal and good ring seal. I see 110-115 @ hot cranking, opposing cylinder plug out. In the 90's with the stepped low compression heads is good.
The Following 2 Users Say Thank You to Motorhead For This Post:
Onan 4.0 BGE Spec K Compression masterfabr Onan Generators 2 10-23-2012 11:51:53 PM
Have an Onan 1maj-1r/1h a12 with low compression coberdas Onan Generators 8 08-30-2012 10:33:23 PM
77 Onan NH series with low compression zetorung Onan Generators 5 09-06-2011 09:35:38 PM
Onan JB Compression Ratio Leon N. Onan Generators 9 03-24-2011 09:40:10 PM
Onan JB Compression Ratio Leon N. Onan Generators 3 03-05-2010 12:26:19 PM
