Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Farm + Industrial Antiques and Collectibles
Farm + Industrial Antiques and Collectibles Old belt driven farm equipment: shellers, milkers, threshers, pumps and antiquities of the industrial revolution.
IHC Burr Mill Help Needed
this thread has 4 replies and has been viewed 551 times
Old 08-28-2018, 08:57:41 AM
jimbo8259 jimbo8259 is offline
Photo IHC Burr Mill Help Needed
So I picked this up this past weekend and have a few questions. Is there supposed to be an outboard bearing at the end of pulley? It is missing the arm and mechanism that moves the pan on inside of hopper. Does anyone have a picture of what it should look like and what rides on the worm gear part on shaft? Would anybody have a copy of manual or better yet the parts I am missing? Thanks for any help.
ID:	317315   Click image for larger version
ID:	317316   Click image for larger version
The Following User Says Thank You to jimbo8259 For This Post:
Old 08-28-2018, 10:28:35 AM
EdDarowski EdDarowski is offline
Default Re: IHC burr mill help needed
There is supposed to be an outboard bearing, beside the pulley. Jebaroni has manuals for it. He helped me when I got mine.
Ed
The Following User Says Thank You to EdDarowski For This Post:
Old 08-28-2018, 12:24:01 PM
Jebaroni's Avatar
Jebaroni Jebaroni is offline
The larger sizes of IHC grinders came with a 3rd (outboard) bearing and stand. You can safely run the machine without it if you are just demonstrating it at shows. Many other brands (like Letz) offered the extra bearing as an option. The worm gear drove a small spur gear with an offset crank attached to it. This crank caused an arm to "wiggle" inside the hopper in order to prevent ear corn from "bridging", or getting stuck in the hopper on its way to the bottom. Again, you can safely run the machine with out it, but if it gets plugged up in the hopper, a broomstick or tapping on the outside of the hopper should work.
ID:	317319   Click image for larger version
ID:	317320   Click image for larger version
ID:	317321   Click image for larger version
Name:	IHC Feed Grinder 004.jpg
The Following User Says Thank You to Jebaroni For This Post:
Old 08-30-2018, 06:46:44 PM
Photo Re: IHC burr mill help needed
I do plan to put a bearing on the end of shaft , I would like to belt it up and see what it can do. So that fork just moves in and out to keep cob corn loose. I thought it would hook to the tab on the pan in hopper or is that just for use for shell corn or small grains. Thanks for the replies.
ID:	317491   Click image for larger version
Old 08-31-2018, 11:43:09 AM
Jebaroni's Avatar
Hey Jimbo,
Your machine has the "supplemental Hopper Bottom" with it, that was used for grinding small grains (like corn that was already shelled off of the cob). When using that extra piece, the agitator bar is not needed, which explains why yours does not have it installed.
what burr mill do i have rsblair Farm + Industrial Antiques and Collectibles 3 12-06-2014 10:13:46 AM
Martin MFG Burr Mill Info & Pics Needed Ironman Farm + Industrial Antiques and Collectibles 3 05-15-2011 06:54:50 PM
Foos scientific burr mill info needed jwx3 Antique Gas Engine Discussion 0 03-02-2011 09:49:02 PM
Does anybody know anything about this burr mill? Meco3hp Farm + Industrial Antiques and Collectibles 17 04-09-2008 09:21:03 AM
Burr Mill ID Ed Carry Antique Gas Engine Discussion 0 03-26-2007 12:39:36 PM
