Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Farm + Industrial Antiques and Collectibles
Farm + Industrial Antiques and Collectibles Old belt driven farm equipment: shellers, milkers, threshers, pumps and antiquities of the industrial revolution.
Fairbanks Morse Pump Restoration
this thread has 14 replies and has been viewed 973 times
Old 09-03-2018, 04:13:44 PM
Dustin D Ehli Dustin D Ehli is offline
Images: 15
Default Fairbanks Morse Pump Restoration
Hey, thought I would do something a bit different and show some pics of a big pump I want to repair.
It's a Fairbanks Morse 3 inch centrifugal.
Been stuck and sitting for a long time, no idea how old it is.
I already have it apart so I will post a bunch of pics of that process.
Needless to say it involved very large torches and lots of aero kroil.
Dusty
First ones are of how it was as I aquired it.
ID:	317789   Click image for larger version
ID:	317790   Click image for larger version
Having a blast preserving the past.
My Youtube Channel
Old 09-03-2018, 04:17:24 PM
Images: 15
Default Re: Fairbanks Morse pump restoration
Lots of heat with huge torch and stuff started to give. Some broken bolts to fix but not that many actually.
Shaft is Heald into bearings with a big spanner nut and lock ring, housing is grease filled
ID:	317792   Click image for larger version
ID:	317793   Click image for larger version
ID:	317794   Click image for larger version
My Youtube Channel
Old 09-03-2018, 04:23:31 PM
Images: 15
Got shaft out and finally got the packing assembly apart without breaking anything.
Only thing I won't remove is the impeller, it can stay on shaft.
As time permits I will clean stuff up and start reassembly, replacing stuff as needed.
Packing is 3/8 square, anybody got any that big they will spare with?
ID:	317796   Click image for larger version
ID:	317797   Click image for larger version
ID:	317798   Click image for larger version
My Youtube Channel
Old 09-03-2018, 04:59:49 PM
Images: 15
If anyone is wonderful what I'm gonna do with it, I have no idea yet, probably belt it to an engine and pump water in a barrel.
All I do know is that it's heavy and big hahah
My Youtube Channel
The Following 2 Users Say Thank You to Dustin D Ehli For This Post:
Old 09-03-2018, 06:59:22 PM
Images: 15
Looks like I will need about 4 feet of 3/8 packing, there are 6 rings plus a brass spacer in the middle to allow the grease into the packing.
I ordered packing, will get the rest of the stuff I need locally, gonna leave it old and rusty looking I think
My Youtube Channel
The Following User Says Thank You to Dustin D Ehli For This Post:
Old 09-05-2018, 06:41:40 PM
Images: 15
Default Re: Fairbanks Morse Pump Restoration
Got new packing from palmetto.
Got the rust ground out of the housing counterbores so that the impeller doesnt stick anymore so I think soon I can start reassembly.
My Youtube Channel
Old 09-05-2018, 07:44:49 PM
Good work. Gonna take some horse power to make it work.
Old 09-05-2018, 09:07:34 PM
Images: 15
Tomorrow I'll get new bolts for the packing glands and start to put it together, should go quick, I'm gonna just silicon the housing and forgo a gasket,
It will just be used for zero pressure display from now on so no biggie,
So outet is 3 inch as stated on tag, inlet is 4 inch but I hope 3 inch will be fine, at the low rpm and pressure I think it will be fine and not affect operation that much.
I plan to use a 55 gallon drum for my display tank and just pump water in a circle.
We will see of it's operable from a flat belt and low rpm, with the way the impeller fits into the housing counterbores I thing it will pump at pretty low rpm, not a lot of bypass is allowed in the housing.
My Youtube Channel
Old 09-06-2018, 07:10:14 PM
Images: 15
Got the packing in, assembled the rotating assembly and after packing the bearings with new grease she spins very nicely, I don't have the packing very tight yet
ID:	318091   Click image for larger version
ID:	318092   Click image for larger version
ID:	318093   Click image for larger version
My Youtube Channel
Old 09-06-2018, 07:23:30 PM
Be tender with the packing gland. Tighten evenly or you could crack it in half. Seen it done. It will probably take 3 or so tightenings to get everything mashed down and sealed, after running.
Old 09-06-2018, 07:37:25 PM
Images: 15
Yes I will pat, it is a 2 piece gland so you can take it out without removing anything.
The shaft is scoured decently so I don't expect great results anyway but should be ok for running it with no back pressure and just a few feet of head for display.
if you could get the impeller off, which I didn't try then you could fix it easy cause it has a brass sleeve on the shaft where the packing rides, I'll see what happens with it as is.
My Youtube Channel
Old 09-07-2018, 06:36:47 PM
Images: 15
Back together, now I have to make flanges for pipe connectors.
Gonna weld 3 inch tubing to flat plate and make them.
Then I plan to use a 55 gallon drum for my tank and see what happens.
Think it will work off a flat belt at fairly low rpm? The impellor fints into recesses in the housings so should be fairly effiecnt id think even at low rpm
My Youtube Channel
Old 09-23-2018, 07:29:55 AM
Images: 15
Flanges made for 3 inch pipe.
Sometime I will.make a barrel and some kind of pulley now for it
My Youtube Channel
Old 09-23-2018, 09:52:33 AM
JWK10 JWK10 is offline
Dusty,
Did this come out of the same box car as your N? Wondered if the RR used the N and the pump to fill the water tower for the steam engines....
Safe harvest...
John K.
Old 09-23-2018, 04:09:22 PM
Images: 15
No,
I bought this elsewhere, i believe it is supposed to be direct coupled to a electric motor.
But I plan to belt drive it for show purposes, no word of the original pumps, either from RR or the city.
I'm imagining the city switched the same pump to electric drive and that is why it wasn't removed with the engine
My Youtube Channel
Fairbanks Morse 1919 6hp Restoration BaileyDC Antique Gas Engine Discussion 1 08-17-2017 12:19:33 AM
FairBanks Morse Z 3hp possible restoration Cespilot Antique Gas Engine Discussion 15 09-21-2015 11:23:54 PM
Fairbanks Morse Z on American Restoration Lewis MacRae Antique Gas Engine Discussion 6 03-10-2014 08:05:46 AM
Fairbanks Morse Z 3hp restoration questions Matt McGivney Antique Gas Engine Discussion 6 10-28-2009 05:50:14 PM
Fairbanks Morse 3HP Z Restoration Harry Antique Gas Engine Discussion 12 05-18-2007 10:27:55 AM
