Go Back   SmokStak > SmokStak® Vintage Heavy Industrial Equipment > Vintage Construction Equipment > Dozers and Crawlers
Dozers and Crawlers Holt, Caterpillar, Cletrac, etc.
Dozers and Crawlers
Cat Thirty Generator
this thread has 9 replies and has been viewed 1398 times
Old 08-27-2016, 06:39:56 AM
Cysco Cysco is offline
Default Cat Thirty Generator
I am looking for a generator and the internal gears for a Cat Thirty
The two Cat numbers in my book for a generator are as follows:
L-1127
1A106 -- BoschRJB 75/6 900/6 RS50
A
Anyone with parts please let me know .
Also any info, pictures, etc so I can possibly know what to look for would be helpful.
Thanks......Bill
The Following User Says Thank You to Cysco For This Post:
Old 08-28-2016, 06:43:38 PM
Ed Bezanson Ed Bezanson is offline
Default Re: Cat Thirty Generator
Bill Cat 30's did come with a generator so the unit could be equipped with lights for night work. Problem is this was a fairly rare option back then. Move forward about 90 years and finding this setup is near impossible. This is a gear driven unit and I think the same generator was used on several model Cats of the era. Hopefully a Cat person with more knowledge will check in and fill in the blanks. Good Luck Ed B
The Following User Says Thank You to Ed Bezanson For This Post:
Old 08-28-2016, 09:12:27 PM
Thanks for the reply Ed B.......I should clarify a bit on the parts I am wanting. I have a pair of correct lights and mounting brackets and also have the housing that mounts to the tractor that holds the generator. I am missing the actual generator and internal gears.
Thanks again for your reply.....Bill
Old 09-08-2016, 05:39:40 AM
If I can't get the gears and generator maybe someone would be willing to get some pictures of the gears and generator. That would be a huge help in at least getting a starting point.
Any help is greatly appreciated........Bill
Old 09-10-2016, 06:34:10 PM
Bill I have a generator and adaptor plate to fit on a Model 20. I can supply pics and some drawings if they will help. I am out in ILL at the George Schaaf auction today then on to Peoria Cat tour, then HCEA National Construction Show next week. Be home after Sept 22 Drop me a PM if I can help. Ed B
Old 10-25-2016, 06:59:59 PM
Looks like plenty of lookers here....almost 400....but nobody left any suggestions, etc.
I'll give a brief update as I have got some dimensions of the gears and am working towards getting those made. As far as the generator I have a got a couple possibilities but nothing definite yet.
Have a good day........Bill
Old 10-25-2016, 09:38:04 PM
Dear Bill Sorry I didn't get back with some pics of my setup. I was on the road when I answered and totally forgot about your inquiry. I will try to get some pics and send them on. Ed B
Old 10-26-2016, 06:17:47 AM
No problem Ed.....I knew you were busy with the small 15 but saw the 400+ lookers and not a single response. I thought someone would have info.
Have a good day.....Bill
Old 11-04-2016, 07:20:56 PM
Bill I finally found the generator that I put away during a shop cleanup this summer. It is a Delco Remy unit and note the adapter that is a spacer to position the gear in correct mesh with its drive gear.
ID:	267262   Click image for larger version
ID:	267263   Click image for larger version
ID:	267264   Click image for larger version
The Following 2 Users Say Thank You to Ed Bezanson For This Post:
Old 11-05-2016, 05:46:47 AM
Thanks Ed....this really helps in my searching. The only difference I can find is the gear is a straight cut gear on a Thirty.
Your help is greatly appreciated.
I am also following your small Fifteen project. Looking good!
Have a good day......Bill
Late Emerson Brantingham Big 4 Thirty Bruce Flatmoe Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 172 05-28-2018 11:02:13 PM
Cat thirty for sale in Maine Ed Sparks Dozers and Crawlers 0 06-21-2015 11:23:19 AM
Caterpillar Thirty JasonPayneCrawlers Dozers and Crawlers 11 08-06-2014 10:00:55 PM
Caterpillar Thirty Pat Bayer Dozers and Crawlers 13 03-26-2013 01:35:15 PM
My thirty dollar saw EricR Chain Saw Collectors 4 06-06-2012 11:07:14 PM
