Go Back   SmokStak > SmokStak® Vintage Heavy Industrial Equipment > Vintage Construction Equipment > Dozers and Crawlers
Dozers and Crawlers Holt, Caterpillar, Cletrac, etc.
Dozers and Crawlers
Todays Find 1945 Cletrac HG-42
this thread has 18 replies and has been viewed 1868 times
Old 02-24-2017, 06:34:12 PM
Nevr-Enuf-Stuf's Avatar
Nevr-Enuf-Stuf Nevr-Enuf-Stuf is offline
Default Re: Todays Find 1945 Cletrac HG-42
Patrick
Name:	DSCN8424 - Copy.JPG
ID:	275789   Click image for larger version
ID:	275790   Click image for larger version
ID:	275791   Click image for larger version
Old 02-24-2017, 06:36:12 PM
One more.
Patrick
Old 02-24-2017, 11:09:05 PM
You have any casting numbers for that block? How long is the block?
Old 02-25-2017, 02:54:51 PM
Block length is 22-1/4". Photos/numbers are all on the left side of the block.
Patrick
ID:	275876   Click image for larger version
ID:	275877   Click image for larger version
The Following User Says Thank You to Nevr-Enuf-Stuf For This Post:
Old 02-25-2017, 06:55:01 PM
Patrick Someone spent a lot of time putting a Herc. Power Unit into an HG chassis. It is one of the more complicated installs I've seen. The engine appears to be mounted higher than the imput into the Transmission. How did they make the connection between the two???? It is amazing what people have done to keep and old tractor going. It is a model UX4 Hercules Power Unit and dates much later than the tractor it is mounted in. Enjoy Ed B
Old 02-25-2017, 07:33:21 PM
Post #12 photo, you can see the guarded driveshaft at an angle. Did a quick internet search, couldnt find any info on the UX4.
Patrick
Old 03-02-2017, 11:04:36 PM
Does anyone know where some rubber track pads can be had for this? Has anyone had luck with making their own, and from what?
Patrick
Old 03-08-2017, 01:51:30 AM
mike french mike french is offline
zimmerman oliver-cletrac parts www.olivercletrac.com
The Following User Says Thank You to mike french For This Post:
Old 03-08-2017, 10:24:30 PM
moteurdelco moteurdelco is offline
U for ''universal''?? JX4D3 is 4''piston,4 cylinder. Short version of the 6 cyl. JXD.
---------- Post added at 09:24:30 PM ---------- Previous post was at 09:22:53 PM ----------
with clutch-reduction?;slow but strong.
Todays Find, Coldwell Cub Twin Nevr-Enuf-Stuf Small Air Cooled Gasoline Engines 7 05-23-2016 06:41:30 AM
Todays Awesome Find, Who Knows What They Are? Nevr-Enuf-Stuf Farm + Industrial Antiques and Collectibles 15 05-10-2016 11:07:34 PM
Todays find...Champion No.1 Nevr-Enuf-Stuf Farm + Industrial Antiques and Collectibles 4 12-11-2014 10:46:13 PM
Todays Find AKMark Antique Gas Engine Discussion 6 04-15-2014 09:09:16 PM
Todays Find Charliehd Antique Gas Engine Discussion 2 01-11-2007 12:06:00 AM
