Go Back   SmokStak > SmokStak® Vintage Heavy Industrial Equipment > Vintage Construction Equipment > Dozers and Crawlers
Dozers and Crawlers Holt, Caterpillar, Cletrac, etc.
Dozers and Crawlers
TD14 is it 6 Volt or Twelve Volt?
this thread has 10 replies and has been viewed 826 times
Old 01-20-2018, 02:27:00 PM
Default TD14 is it 6 Volt or Twelve Volt?
I am going to try to star a n International TD14 in a estate. The 2 batteries are missing. One site said it took a 6 volt battery. I assumed it was two 12 volt batteries. What does it take two 6 volt batteries or two 12 volt batteries?
Richard W.
Old 01-20-2018, 02:44:00 PM
Heins Heins is offline
Default Re: TD14 is it 6 volt or twelve volt?
It is a 12 volt, one 12 volt battery or two 6 volt batteries hooked in series.
Old 01-20-2018, 02:54:10 PM
Exclamation Re: TD14 is it 6 volt or twelve volt?
If it has a large battery bix, it also may have used 2 - 12 volt batteries in parallel, if the batteries were undersized for the tractor starter load requirements.
Old 01-20-2018, 04:37:46 PM
It has a place for 2 batteries. I may have a picture of it. I will check to see if I have a picture.
Richard W.
Old 01-20-2018, 04:47:26 PM
I would go for the 2 - 12 volt/parallel set up. Two 6 volt in series would work but price???
Old 01-20-2018, 04:48:17 PM
I looked on my phone and I don't have a picture and the tractor is about 100 miles away. I will get a picture later. Would it hurt to try two 12 volt batteries? I don't know where to look to find the voltage?
The tractor is stored inside and hasn't been started in years. I drained old gas out of it. Need to clean the 1.5 gallon tank. The owner passed on last January and he was looking for a blade for it. It has a winch and hydraulic cylinders for a blade. What is this worth if it runs?
Richard W.
Old 01-20-2018, 05:23:35 PM
Two 12 volt batteries will work, just make sure the positive post are hooked together and the negative posts are hooked together (parallel).
Old 01-20-2018, 10:09:13 PM
Mark Fralick Mark Fralick is offline
Default Re: TD14 is it 6 Volt or Twelve Volt?
2 6 volt batteries have more starting amps than 2 12 volt batteries . Cat has been doing this for years
Old 01-21-2018, 12:24:27 AM
Most farm tractors use two 12 volt batteries for 12 volt systems. Our four wheel drive tractors use three 12 volt batteries for 12 volt systems.
We had a TD-14 that we started with a plug in jumper cable from our diesel pickup. Both the TD-14 and the pickup had plug ins that we plugged the jumper cable into. We still start our Galion grader with a TD-14 engine that way.
It doesn't take much to turn the IH engines over when they on switched to gas. The older IH TD-14 diesel were started with a hand crank.
Old 01-21-2018, 07:03:06 AM
Firewoodguy's Avatar
Firewoodguy Firewoodguy is offline
I only had 1 12V for my TD14A
Trying to Convert 6 Volt Tiny Tim Ggenerator to Charge 12 Volt Tim Venetis Generators & Electric Motors General Discussion 0 12-19-2017 10:07:29 PM
Interesting---12 Volt Lights off 24 Volt Generator MEP=016b SDHomesteader Military MEP and Aircraft Gen-Sets 10 10-16-2009 08:56:53 PM
Hi Guys! Onan CCK 3CR 120 volt or 240 volt envelopes2007 Onan Generators 26 12-27-2007 09:38:47 PM
12 volt or 6 volt for buzz coils Will Magnetos, Ignition Coils and Spark Plugs 23 03-31-2006 03:19:06 PM
32 volt yes, 32 volt auto start Kohler Frank DeWitt Kohler Generators 4 08-01-2005 08:54:08 AM
