Onan 1990 JC
this thread has 15 replies and has been viewed 2860 times
Old 12-11-2008, 09:07:49 PM
don-mar don-mar is offline
Question Onan 1990 JC
i have a 1990 jc and have it hooked up to a 60 amp auto transfer switch . can i get a 200 amp auto switch and hooket it up so i wll have 200
amps when the electrice come back on ? it is a onan15kw jc
Old 12-12-2008, 01:29:48 AM
Ted_Cool Ted_Cool is offline
Default Re: Onan 1990 JC
That's right - size for the max.
Old 12-12-2008, 07:02:35 AM
Gunny Gunny is offline
Well.........
Yes if you have 200 amp service to your house you should have a 200 amp switch.
The Onan air cooled gensets are 3 wire start and all of the Automatic Switches sold today are all 2 wire start. In short, it won't work properly. Can be modified to work.
I have a 12.5 DJC supplying power to my house theough a 200 amp Kohler ATS. I changed out the Onan controler to an ECU, works great.
Old 12-12-2008, 07:53:41 AM
don/t onan make a 200 amp auto switch?
Old 12-12-2008, 08:59:21 AM
EricWood's Avatar
EricWood EricWood is offline
Yes--they have switches in the 200 amp range in their residential line up--the newest ones offer SE (service entrance breaker) as an option inside the cabinet.
The OTEC is probably the most economical commercial model available from them--225 amp being the closest size. OTEC-series is a really good switch, as it uses the OT III transfer mechanisms that have been around for many years now. The little blackbox controller that operates it is easy to program.
eric
Old 12-12-2008, 10:34:09 AM
Billy J Shafer's Avatar
Just keep in mind a JC will not carry 200 amps.
Old 12-12-2008, 01:03:59 PM
eric
Eric:
What is Onan doing for a 3 wire start now days? They used to make a converter box but last I heard, they discontinued them.
Old 12-12-2008, 05:36:07 PM
The last I heard Onan no longer builds 3 wire units.
Old 12-12-2008, 07:46:29 PM
EricWood's Avatar
Gunny/Billy,
I had someone do some checking for me a while back, and found there were 15 at the factory.
They have ( 8 ) of 300-2860-01 and ( 7 ) of 300-2860-03.
Read $$$.$$
I suspect once these are gone, they are indeed gone. I had drawn up a design for a 2-3 wire convertor recently, that was strictly low (DC) voltage. Unfortunately, didn't make the next back up before the laptop crashed last week. I can draw it up again, if anyone is interested. (to keep the J-series folks 100% original when desired.)
I like the ECU conversion, Gunny. Simple and reliable.
eric
Old 12-12-2008, 08:07:59 PM
Dslsmoke Dslsmoke is offline
.....I can draw it up again, if anyone is interested. ......
Yes, Yes, Very interested, that way I can get rid of my LTEU60-3/7341F # F790427150 (Perhaps someone might be interested in this unit ) and upgrade to a 200 amp switch myself.
The question now would be,.... Which switch would be recommended for this upgrade?
Right now I have a 12.5 DJC powering my house through a manual 200 amp switch between the meter and the service disconnect.
Dslsmoke
Kohler 2.5CMZ-RV Toyota 1990 Eddie Pratt Kohler Generators 2 12-31-2005 11:06:45 PM
