Wisconsin Engines
Difference between Wisconsin BKN & AENL
this thread has 3 replies and has been viewed 2037 times
Old 06-07-2013, 08:17:06 AM
BlkBeard BlkBeard is offline
Default Difference between Wisconsin BKN & AENL
Good morning;
What's the difference between the BKN or AKN, and the AENL?
I'm restoring some Baird Beaver Tractors which used AKN's & BKN's and there is a AENL in need of repair available locally.
It looks about the same. Are any of the parts interchangeable?
Any help would be greatly appreciated
Old 06-07-2013, 05:41:47 PM
RSCurtis RSCurtis is offline
Default Re: Difference between Wisconsin BKN & AENL
They are two completely different engines. The AENL is about 50% larger than the AKN or BKN.
The Following User Says Thank You to RSCurtis For This Post:
Old 06-07-2013, 06:49:01 PM
Zira Zira is offline
An ACN will look identical to the BKN but slightly less hp (about the same as the AKN). An ABN is the twin of the AKN but less hp still (4.2 or so). The AENL is bigger & carb, etc. is on the other side. All of these are very common, I would keep looking for what you want.
The Following User Says Thank You to Zira For This Post:
Old 06-07-2013, 07:42:00 PM
Thanks.
I'm ashamed to admit that looking at it, it escaped my attention that the carb and exhaust are on the opposite side. Might buy it and rebuild it anyway. Would be good for an old tractor with a blown motor
Wisconsin AENL? GHanners The Junque Drawer 4 09-30-2012 10:47:37 AM
Why won't it start? Wisconsin AENL jumpinjivinjoe Wisconsin Engines 11 03-22-2009 04:01:16 PM
FOUND in a corner - Wisconsin AENL Keith Thomas Wisconsin Engines 6 01-31-2009 03:13:19 PM
Wisconsin AENL Engine SkyHarborCowboy Wisconsin Engines 6 03-14-2008 08:50:32 PM
Wisconsin AENL Issues. Need Help! power king steve Garden Tractors / Mowers / Scooters 3 08-06-2007 09:23:05 PM
