Onan 7500 HDKAJ stops, shows 3-11 code
this thread has 9 replies and has been viewed 3446 times
Old 11-07-2013, 05:37:21 PM
Pusherpilot Pusherpilot is offline
Default Onan 7500 HDKAJ stops, shows 3-11 code
Hi all,
This is a problem that has plagued me with this generator since we bought the RV! While it was still in warranty Onan changed the "board" for this problem and it worked for a few years OK. This is a ten year old unit with only a few hundred hours on it. Last year I had a good dialog here when I couldn't get it to start out at Quartzsite after sub freezing nites. I finally determined that it was the temp sender and replacing it fixed that problem. I've had a health issue that has kept the RV parked for about 7 mos without running anything but now we're ready to go and sorting out all the problems that letting it sit brought on.
Now it's cranking after the proper delay for the glow plugs to heat up but only runs for a few seconds before it stops an shows a 3-11. That's a overcurrent fault, the same code it's shown since the beginning. I never got it to run long enough to pick up the load so there was no out put from it to the coach transfer switch. The manual advises me to turn the circuit breaker on the unit off and try again. The result is the same with the unit running from 2-3 seconds to around 30 sec before faulting again.
Anybody seen this before? Any ideas?
Ron
Old 11-07-2013, 08:08:21 PM
Gunny Gunny is offline
Default Re: Onan 7500 HDKAJ stops, shows 3-11 code
Post the COMPLETE Model/Spec/Serial number.
Old 11-08-2013, 12:49:14 PM
Complete Model spec and s/n are:
HDKAJ11451H
Spec H
s/n H030531865
Old 11-08-2013, 01:14:39 PM
Kpack
We'll look for a service manual in a little while.
Old 11-08-2013, 02:26:35 PM
Kpack
Didn't know if you had the service manual. 981-0522B 7-99
http://www.cumminsonan.com/www/pdf/m.../981-0522B.pdf
Old 11-08-2013, 04:12:53 PM
Using the troubleshooting guide on page 18-9 the fix for this is to replace the controller.
Does anyone have experience with this code, 3-11, not being the result of a controller failure?
If all else fails and I need a new controller, are there options as to a source?
Thanks for the rapid response with the manual.
Ron
Old 11-08-2013, 05:31:03 PM
No p/n's in the shop manual? Anyone have a p/n for the controller?
Thanks!!
Ron
Old 11-08-2013, 06:13:33 PM
Kpack
Here's the parts manual.
https://www.dropbox.com/s/hnpaymnt3h...201211hdkp.pdf
Old 11-08-2013, 08:09:50 PM
Ron
Check with Flight Systems. They may be able to repair the board you have (if it is not potted) for much less than a replacement. I have had them repair several & bought several boards. I have not ever heard anyone here at The Stack that was not completely satisfied with them.
The Following 2 Users Say Thank You to Max Thompson For This Post:
Old 11-10-2013, 09:11:04 AM
J. McNugget's Avatar
J. McNugget J. McNugget is offline
eMail NOT Working
Flight systems repaired the control board of the larger brother of this set (HDKAG) about 3 years ago. It has probably logged 3,000 hours since then without issue. They are very competent, and quick too.
John
The Following 2 Users Say Thank You to J. McNugget For This Post:
Onan 7500 HDKAJ Onan wont turn over/start md00738 Onan Generators 7 11-04-2013 09:09:30 AM
Onan 7.5 HDKAJ Lew in Florida Onan Generators 3 09-12-2013 08:52:12 PM
onan 7500 Quiet Diesel code 36 crempud Onan Generators 1 05-07-2012 10:08:09 PM
Onan 7.5 HDKAJ Problems KIX Onan Generators 11 02-10-2010 10:50:27 PM
Onan 7.5 HDKAJ Peter Parry Onan Generators 2 10-30-2007 09:07:43 PM
