Go Back   SmokStak > SmokStak® Vintage Heavy Industrial Equipment > Vintage Construction Equipment > Lifting and Loading
Lifting and Loading Pay loaders, Fork lifts, tow motors, jacks and hoists.
Lifting and Loading
towmotor propane forklift continental engine vaporizer
this thread has 14 replies and has been viewed 7292 times
Old 04-08-2015, 10:32:14 AM
FWurth's Avatar
FWurth FWurth is online now
One Millionth Post
Images: 4
Default Re: towmotor propane forklift continental engine vaporizer
The reason I ask that question is that the shut off valve on those tanks aren't all the same as I recall. I think that the newer tanks have a safety valve that automatically shuts off if the line is severed, the two types likely won't interchange. So if you try to use an old tank on a new system it won't work and likewise if the you try a new tank on an old system. Most have been changed over but not all. It's been a while since I had anything to do with them but that's what I recall.
Old 04-08-2015, 11:33:53 AM
dkamp dkamp is offline
eMail NOT Working
Motor fuel tanks are different from domestic (heat/gas grill) tanks, and in both motor fuel and domestic tanks, there are safety features whose designs have changed over time... some ideas being much better than others, so it IS possible that the tank has some feature that isn't compatible, or is downright not working... and some 'safety concepts' are actually more dangerous than not. Safety features often lead to complacency and ignorance which becomes a much greater hazard.
SOME tank systems have 'excess flow protection' in them... it's a valve that senses fuel flow velocity, and at a point above a certain velocity, the valve will shuttle to a lock-out position. This MAY be an issue... so worth investigation.
Another note- Propane and gasoline are really not much different in one respect- they're both liquids at some point. Consider that if it's -50F ambient temperature, you can dip a coffee cup of liquid propane right out of a bucket, funnel it into the bowl of a carbeurator, and start the engine like it's gasoline. If it's +210F outside, you'll need to keep that gasoline in an enclosed pressure vessel and pipe it through a propane system. It's all a matter of relative perspective.
Old 04-08-2015, 12:42:08 PM
2wheelBob 2wheelBob is offline
Dieter,
Any chance you can post a pic of your vaporizer and carburetor? It would be helpful to see what system your lift has.
From your original description I think I could rule out an "Impco" system. When you say the vaporizer was attached to the thermostat housing it makes me think you have a "J&S" style system (odd, most Towmotors in my neck of the woods ran Century or Beam systems)
* Double check your Rego female coupling, on your lifts gas hose, for a displaced tank o-ring..sometimes the tank's male Rego o-ring will stay attached to the female when you unscrew it from the tank, when you attach it to the next tank no gas will flow as the double o-ring prevents full engagement of both halves of the coupler.
Old 04-09-2015, 10:17:38 AM
dieter dieter is offline
Originally Posted by 2wheelBob View Post
Dieter,
I am not near the forklift right now.
It is mounted on the thermostat housing which has the word "zenith" on the casting. The actual mechanism/heat exchanger is aluminum where a solenoid valve (Clark brand) is attached to the inlet. It has a large threaded screw with lock nut which adjusts and exerts pressure on a spring which applies pressure to a diaphragm which opens or closes a light-spring loaded "ROUND/FLAPPERLIKE" valve, which allows the liquid/gas to go out through to the carburetor. I have seen a picture on someone's website for a repair kit with a Caterpillar brand name; it gave no part name. The only thing that was damaged was an eight screwhole gasket and I did not want to spend eighty dollars for a gasket; the diaphragm was tight. Other than the input solenoid valve, there is no electric to the "vaporizer".
Is this recognizable?
Old 05-25-2016, 07:31:14 AM
WillysOverland WillysOverland is offline
e bay sells impco vaporizers cheap. I needed one and when I took the old one off the info was on the side facing the machine where I couldn't see it. my machine starts right up and runs perfect now. well worth the 100 bucks. I spent more time thinking about fixing it then it took to fix it.
Old Towmotor Forklift Fred Prichard Lifting and Loading 14 07-09-2018 05:09:21 PM
towmotor 410lp 4 cyl continental lpg fuel calvertmillwright Farm + Industrial Antiques and Collectibles 7 04-06-2015 04:09:43 PM
Towmotor forklift continental engine Tom Rosewood Lifting and Loading 7 03-09-2015 11:05:32 AM
Problem propane forklift. Greg Shipley Lifting and Loading 14 08-08-2012 02:33:51 PM
Towmotor Propane Line Nat Wheatley Antique Gas Engine Discussion 7 05-03-2012 01:52:29 PM
