Go Back   SmokStak > SmokStak® Vintage Heavy Industrial Equipment > Vintage Construction Equipment > Lifting and Loading
Lifting and Loading Pay loaders, Fork lifts, tow motors, jacks and hoists.
Lifting and Loading
Daewoo Forklift - Lift Cylinder Repair
this thread has 32 replies and has been viewed 1470 times
Old 04-01-2018, 02:15:16 PM
Troll's Avatar
Troll Troll is offline
Default Re: Daewoo Forklift - Lift Cylinder Repair
Originally Posted by Heins View Post
On your pallet what kept your ram from blowing out of the barrel? It probably couldn't travel far enough.
These had pistons on the bottoms of the rams. I had everything completely apart.
Old 04-01-2018, 04:13:55 PM
Ifix71 Ifix71 is offline
Now that everyone knows how a single acting cylinder works, it is time for a quiz.
How do you replace the seal in this cylinder? It has a wiper seal and an "0" ring to seal the oil in the cylinder.
These are always fun to spring on the new guy in the shop, the first hint we we tell him is, How would a gynecologist go about it? While he has that stupid look on this face tell him to take the fitting out and look in there. These are found on combines and some John Deere 3 point hitches.
Old 04-01-2018, 10:53:36 PM
Heins Heins is offline
To take the cylinder apart, you have to work through the port where the oil goes into the cylinder. The ram has two grooves, one large and one small dia. When the snap ring is in the large groove, the ram won't come out of the barrel. To remove the ram, the snap ring has to be in the small dia groove.
OLD Diesel Fork Lift Cylinder Packing Jamie Darian Brown Lifting and Loading 7 02-07-2018 09:21:29 AM
CASE Terra-Lift M-3 Fork lift on tracks Tom Street Lifting and Loading 0 06-04-2017 09:38:38 PM
Pettibone-Mercury GS-60 Forklift Mast Cylinder tempered-flame Lifting and Loading 0 06-21-2016 02:08:45 PM
Ford NAA lift system repair and rear pulley uglyblue66 Antique Farm Tractors 7 02-15-2015 02:16:24 PM
Clark Forklift Hydraulic Problem, no flow to cylinder reservoir dalmatiangirl61 Lifting and Loading 16 01-12-2012 03:46:20 PM
