Onan 4.0kW Generator has been sitting for at least 6 years
this thread has 32 replies and has been viewed 1296 times
Old 04-20-2017, 12:52:55 AM
Motorhead's Avatar
Default Re: Onan 4.0kW Generator has been sitting for at least 6 years
Did you pull the main jet out of the carburetor body and clean the small holes in the nozzle?
Back of 1958 5CCK
Contractors model
On trailer owned by
"Ma" Bell.
Old 04-20-2017, 01:06:34 AM
twitchee2 twitchee2 is offline
Yup, everything is out except the slow speed jet, need to get the right size screw driver for it.
Old 04-20-2017, 09:26:55 PM
Ben Cowan Ben Cowan is offline
get a killawatt meter home depot or lowes etc. cheap meter but it measures Herz. It will also let you plug into house power and plug one item at a time into the meter and measure the amp load or watts that one item uses, this it great for loading up our small gensets for testing purposes. Luck, Ben
Old 04-21-2017, 12:18:33 AM
It lives!!!!! Just needed a good carb cleaning to free up everything!
Makings 128Vac No load, drops down to 117-120Vac with the AC running, fridge on and Microwave going! I might try and turn this down just a tad.
Just need to get some new spark plugs, change the oil/filter and add a fuel shut off valve and she should be all set. Thanks for all the help guys!
Old 04-21-2017, 05:34:13 AM
Handyhiker1 Handyhiker1 is offline
Adjust it by the Hz at load and no load. This is more important then the actual voltage.
Congrats by the way!!
Old 04-21-2017, 01:02:49 PM
len k len k is offline
Originally Posted by twitchee2 View Post
...... Just needed a good carb cleaning to free up everything! .....
When I pick up free engines I don't even bother trying to start them anymore, they never do. First thing I do is pull the carb and clean it . They always have gum, dirt or water in them, then they start. Welcome to the wonders of ethanol loaded gasoline. Use gas stabilizer or you may have to clean it again if you let it sit for few months.
Old 04-21-2017, 01:38:22 PM
Yeah, I knew that too (dirt bikes) and to top if off I live in CA so the gas goes bad even faster!
Old 04-21-2017, 02:34:52 PM
Once I was cleaning a carb over a 18 inch pizza pan to catch the gas. Was about 1/4 inch of gas in the pan, when I came back ~15 minutes later I saw a watery layer in bottom of pan that was not there before. The ethanol had sucked the humidity out of the air, thing was it was summer but not oppressively humid.
  #29
Old 04-22-2017, 02:05:41 PM
OnanParts's Avatar
OnanParts OnanParts is offline
Originally Posted by pegasuspinto View Post
I bet you are the first one to hook an expensive 'scope to the fuel pump power lead. So no frame of reference to know if what you see is a normal by-product of how the set works...
Scopes and old Onan gensets? No use at all.............
The Following 2 Users Say Thank You to OnanParts For This Post:
  #30
Old 04-25-2017, 12:04:21 AM
So looks like everything is all set, got some fresh oil in it and i put a fuel shut off in line. I was planning on letting it run itself out of gas ever time I am going to put it away for a while in hopes the carb will not gel up to much. Is there any concern with doing that?
Old 04-25-2017, 04:46:10 AM
Ray Lynch Ray Lynch is offline
Shouldn't be a problem. Check that load is dis-connected beforehand.
Ray
Old 04-25-2017, 12:37:07 PM
Disconnect the 120V load ( shut off circuit breaker) first. Shutting down with high load supposed to stress the $225 AC voltage reg, sometimes to failure.
Old 04-25-2017, 05:22:04 PM
geezer88 geezer88 is offline
Ray
I always like to run with no load for a few minutes anyway for cool down. Shutting off the gas makes a nice cool down timer.
tom
Onan 4.0BF-3CR/16000B RV Generator Startup After Sitting for 6 Years farmer52 Onan Generators 26 10-21-2015 11:50:52 AM
1911 FBM 4 hp T after sitting many years Mark S Frank Antique Gas Engine Discussion 5 11-22-2013 10:26:20 PM
Onan 20ES Starting after Sitting for 10 years Curtis 916 Onan Generators 15 11-23-2012 02:44:36 AM
onan engine sitting for years lafhouse Onan Generators 14 09-09-2011 07:50:47 AM
Sitting 50+ years the Gilson runs Brian.P Antique Gas Engine Discussion 17 02-10-2008 07:51:29 AM
