SX460 Voltage Regulator for Old Onan Generators
this thread has 94 replies and has been viewed 9180 times
Old 11-05-2014, 08:54:41 PM
Jim McIntyre's Avatar
Default SX460 Voltage Regulator for Old Onan Generators
First off, I'm no expert in this area. But I have spent some time troubleshooting, replacing, designing and building voltage regulators for gensets. A few years back I became aware of a very common voltage regulator for generators that was referred to as an SX460.
A quick search on eBay shows up many of these. They are even available on Amazon. Here's what they look like:
Near as I can tell, the SX460 was a regulator designed 'back in the day' by Newage Stamford. I think Cummins may have bought Newage. Anyway, the manual for the SX460 shows up on Cummins site:
https://www.cumminsgeneratortechnolo...specification/
I've never checked to see what Cummins charges for an SX460, but I'd guess it's a touch more than $29.99. Clearly, the eBay SX460 is a Chinese knock-off. Hopefully a 'clone'. But honestly, I have no idea.
So that brings up the first issue. If you're not willing to tinker around with a no-name $29.99 piece of electronics, read no further. These things are cheap, and maybe for a reason. If you have no sense of adventure, despise Chinese knock-offs, or need a reliable genset for your grandmother's heart-lung machine, just move on...
That said, there's no good reason a decent $30 voltage regulator shouldn't be available. These things aren't complex, full of expensive parts, or require years of development to design.
So, I bought one...
And I put it in my Onan 7.5 DKD. It's working fine.
The specs for the SX460 have a couple of things to watch out for.
  1. First off, the SX460 is designed for brushless sets. (If you want to try it in something with brushes, think twice. It might be OK, but I do see some issues). So assuming you have a brushless set, like a DKD, DJE, JC, etc, these ought to work. They're rated for 4A of field drive current, so they ought to be good for larger sets, too.
  2. Next, the SX460 specs call for a 15 ohm minimum field resistance. You need to know what your field resistance is. Then, if it is less than 15 ohms, add in some series resistors to get a 15 ohm total. My DKD needed 8 ohms added to get this.
  3. Finally, remember this thing is going to fail someday. Maybe soon, maybe later. But when it does fail, it'd be nice if it didn't take your generator and AC loads with it. This is the tricky part. Onan, in their original design for the YD-based 'J' sets included a field circuit breaker, probably recognizing the same issue with their electronic regulator. So, figure out how much field current you need, and add in a fuse.
The Following 8 Users Say Thank You to Jim McIntyre For This Post:
Old 11-05-2014, 09:21:11 PM
Default Re: SX460 Voltage Regulator for Old Onan Generators
This sounds like something I would like to play with someday. It would sure beat $130 for a VR board in the JCs.
Old 11-05-2014, 09:32:40 PM
Billy J Shafer's Avatar
Cummins did buy Newage. Sold them for quite a bit more than 30.00 dollars.
The Following 2 Users Say Thank You to Billy J Shafer For This Post:
Old 11-05-2014, 10:18:39 PM
Isaac-1 Isaac-1 is offline
The Chinese clone SX-460's seem to come in a few quality grades, or at least variaitons, some have labels with terminal markings, some don't, some use better quality premade jumpers) I have used a couple on MEP-016 series 3KW generators, so far with fairly good luck (one defective unit that fried right away). I have not bought one in a couple of years but at that time they were selling for around $70-$90 shipping from the U.S. or $40 with a 30 day non express shipping from China. It is strange replacing a shoe box size AVR with something the size of a pack of playing card, but they do seem to work.
Old 11-05-2014, 11:38:57 PM
len k len k is offline
For my own gen think I'ld prefer to rebuild my reg than buy China, at least for my primary gen that supplys my heating furnace.
In the middle that TO-220 transistor on a heat sink is likely the main power transistor (hot). If it feels too hot put a fan on it or move it in to a flow of cooling air
Many times in electronics it's the hot running power semiconductors that die. Many companies don't pay enough attention when designing to keeping them cool and derate power dissipation for hot heat sinks. Biggest thing for reliability is if the power transistors run hot you need to put a fan or bigger heat sink on them, MUST keep the die junction temp below ~ 180 deg F MAX. (max limit on case temp is a lower temp, thermal resistance of package)
On size I notice the JC type regs are designed the old fashion way , with lots of space and big bulky components. My NHM reg uses alot of surface mount components in the logic stuff, they don't run hot. That's likely how they shrink it down in size, and maintain reliability.
Old 11-06-2014, 12:06:56 AM
The best way to keep parts cool is to not dissipate power if you don't have to. I'd guess the SX460, like the Onan YD regulator, uses SCRs, not transistors. So the dissipation boils down to 4A (at MAX) across a couple of forward-biased silicon junctions. Under 6 Watts. If the SX460 uses MOSFETs, the dissipation is probably even less. It is not a linear regulator.
My JB and DKD only need about 1 amp of field excitation. The SX460 doesn't even get warm to the touch.
I'd be inclined to repair a broken Onan regulator too, except that the only one that I've had fail was one of the 'marine' style ones, and completely potted. Definitely NOT worth the bother.
Old 11-06-2014, 12:15:09 AM
My Onan reg (NHM) had aluminum case, I drilled a hole in back and added 150 psi air. Case was mildly corroded so potting didn't stick, and whole potting block popped out in one piece. But yes picking potting is a pain even with my clear potting. Guess that's why it's still sitting in a box waiting for me to finish it. But $8 for IGBT vs ~ $250 for reg is an incentive.
Really what I want to do is get it running and see how hot the IBGT gets and modify heat sink if I have to. My field is 3 amps max, TO-220 package replacement IGBT dissipates ~ 7 watts, free wheeling diode is next to it , maybe 2 more watts there (PPM). Big gap in contact between bar IGBT is on and larger Al case, big burr on drill hole
Old 11-06-2014, 08:15:48 AM
EricWood's Avatar
EricWood EricWood is offline
Flight Systems sells their version, with a substantially more robust heat sink, for $159. FYI... The CPG genuine SX460= $434. All the Newage bits and pieces are a little spendy-- just the nature of the business.
All OEMs will charge premium for their "original" parts. That's what make NAPA et al successful.
The Following 2 Users Say Thank You to EricWood For This Post:
Old 12-10-2014, 07:43:26 PM
BigBlockChev's Avatar
So If I was going to use one of the SX460 VRs on a DJC which has a field resistance of around 12 ohms I should use a 4 ohm resistor in series with the field. What wattage rating would be needed to be safe. I believe the field current is in the 1A range so am thinking a 15-20W resistor would be appropriate. It would seem to make sense to run it through the original field breaker as it is handy and should be close to the correct size? Cheers Dan
Old 12-10-2014, 08:40:25 PM
Yep - your approach looks good to me...
15 ohms, being the minimum, you might want to go a touch higher...
I got mine at Mouser.
Onan JC with no Voltage Regulator flagmaster Onan Generators 29 10-22-2013 07:42:06 PM
Feedback on import automatic voltage regulators, like the sx460 CougarMountain Military MEP and Aircraft Gen-Sets 5 08-05-2013 09:04:23 PM
Onan 15.0JC Voltage Regulator prestonfm Onan Generators 11 01-22-2011 05:16:58 PM
Onan 5GO Voltage Regulator TomFG Onan Generators 21 03-07-2010 10:27:40 AM
Looking for Onan voltage regulator rwenig Onan Generators 0 12-23-2004 11:38:42 AM
