SX460 Voltage Regulator for Old Onan Generators
this thread has 94 replies and has been viewed 9180 times
Old 12-11-2014, 04:59:41 PM
PopsGarage PopsGarage is offline
Default Re: SX460 Voltage Regulator for Old Onan Generators
Thank You the arcing at the brushes could be a concern they should be solid on the slip rings
Old 12-11-2014, 05:53:06 PM
Nazrat Nazrat is offline
Here's the simplest version of the instructions that I can find:
http://www.dieselgeneratorsmiami.com...-REGULATOR.PDF
-Tad
Old 12-11-2014, 07:10:49 PM
Jim McIntyre's Avatar
Watch out for the 380V reference in that one - They're referring to the line-to-line voltage, but connect the regulator from line to neutral, so it sees 220V.
I had a link to Cummins' manual in my first post of this thread...
Old 01-06-2015, 12:20:11 AM
BigBlockChev's Avatar
Well now that the Hockey game is over I can go back to thinking about generators. I finally got around to installing the SX460 on my 12Kw DJC. Pretty darn simple removed the original VR board from the housing , put 5 ohm 25W resistor in series with the existing exciter breaker to bring the total up to the 17ohm range. Put the 110V jumper on the regulator in the indicated spot. Mounted the VR on a couple of straps in the original position. Connected it up to the original terminal connectors and were done. I adjusted the voltage fully clockwise as per instructions and fired up the gen . Works perfect , I measured 400Ma exciter current with a 1500W load on the gen, went up another 100Ma when I put another 1500W on load. I had 2 running gens but only 1 VR board , now they both work. I am ordering a spare as they are cheap enough to keep on hand. Thanks for everyones help. Cheers Dan
The Following User Says Thank You to BigBlockChev For This Post:
  #25
Old 04-07-2017, 08:46:07 AM
mheltunen mheltunen is offline
I am looking into installing a sx460 into my 7.5 JB as well. My question is where to hook up the resistor to bring the field resistance down to the recommended level. I'm assuming from what I have rea in earlier posts that it is wired in series on either the F1 or F2 wire but unclear which one (or does it matter). Thanks
The Following User Says Thank You to mheltunen For This Post:
  #26
Old 04-07-2017, 05:42:08 PM
Dennis19508 Dennis19508 is offline
It doesn't matter. But as pointed out it is also good to keep the field breaker as well - that just goes in series with the field resistor and field winding.
The Following User Says Thank You to Dennis19508 For This Post:
  #27
Old 04-07-2017, 11:02:34 PM
Yes, good point Dennis. I will do that. Ordered the sx460 up tonite and a 5 ohm 25 watt resistor. Waiting on a few other parts and hopefully will have it running soon. Still hunting for a few items but I don't need it operational for a while.
Old 04-11-2017, 05:08:55 PM
Recived my sx460 today. The directions are a tad unclear but I will try to explain what I think has to be done. My jb has 4 leads going to the voltage regulator and they are labeled : F1 , F2 , 1 , 2. On my picture I circled in pink where the F1 and F2 leads will go ( a resistor will be wired in series with the F1 lead. For the remaining 1 ,2 leads I believe they will go to the terminals circled in white. Sounds like on either the 1 or 2 lead a 5A 250V fuse should be wired in series. Any idea which lead should fuse should be on and which of the 2 terminals (circled in white) do the 1 and 2 wires lead to. Again all help is greatly appreciated.
Old 04-11-2017, 06:06:50 PM
Leon N. Leon N. is offline
Re post 21.Unles I am missing something, if this post is talking about replacing a VR for a generator which has slip rings and it is a JB, then the V & R values being discussed are incorrect.
Old 04-11-2017, 06:19:46 PM
My mistake Leon. Rookie error I posted this under the wrong post.
Perhaps I mis understand the etiquette but I thought this was a thread for the sx460 voltage regulators.
Onan JC with no Voltage Regulator flagmaster Onan Generators 29 10-22-2013 07:42:06 PM
Feedback on import automatic voltage regulators, like the sx460 CougarMountain Military MEP and Aircraft Gen-Sets 5 08-05-2013 09:04:23 PM
Onan 15.0JC Voltage Regulator prestonfm Onan Generators 11 01-22-2011 05:16:58 PM
Onan 5GO Voltage Regulator TomFG Onan Generators 21 03-07-2010 10:27:40 AM
Looking for Onan voltage regulator rwenig Onan Generators 0 12-23-2004 11:38:42 AM
