Sacrificial Onan 4.0 BFA - A JohnnyC Executive Decision
this thread has 443 replies and has been viewed 20329 times
Old 07-15-2016, 01:12:23 PM
JohnnyC JohnnyC is online now
Default Re: Sacrificial Onan 4.0 BFA - A JohnnyC Executive Decision
Originally Posted by I like oldstuff View Post
Yellow is on to something here. This unit definitely needs some recognition for it's big win. How about going online and printing up a stick on label or two for a couple bucks.
Design something a bit more creative than this basic example I quickly keyed in here. http://www.stickeryou.com/2/stickermaker#
Wow! That drawing is great! I would like exactly what you got, but put a small picture of the Chumpion 4000 in the background with an Onan lightning bolt through it.
JohnnyC
New Jersey
Old 07-15-2016, 02:30:04 PM
Just go online to one of the many u make it sites for signs and labels. Get creative, plop a pic in and whatever your text is. Note that many can be made on clear film so the paint is visible.
Then see what it'll cost. It should be fun seeing what you come up with.
Old 07-15-2016, 03:25:41 PM
I played with it for a little bit.
Old 07-16-2016, 07:34:09 AM
PopsGarage PopsGarage is offline
Very cool, I would like to see one with the chinkarater going up in smoke
Bob
Old 07-16-2016, 07:51:40 AM
Hopefully I will have time to play with the graphics application and come up with something, but the two suggestions look great!
Thanks!
JohnnyC
New Jersey
Old 07-16-2016, 10:46:47 PM
This evening I spent an hour and started to tear down the 4.0 BFA. So far, so good, but I got more to do before I start to strip paint, rust and other corrosion.
Pictured below:
1) This picture shows where I'm at. As you can see, I removed one of the heads. I need to drill out a seized and snapped bolt that secures the tin to the head. There was no room to drill and tap with the head on the block.
2) This picture shows a pile of parts. I will sort them out later.
3) This picture shows the affects of years of oil on the rubber isolator mounts. Time for new rubber isolator mounts.
That's all for today.
JohnnyC
New Jersey
ID:	258355   Click image for larger version
ID:	258356   Click image for larger version
The Following 4 Users Say Thank You to JohnnyC For This Post:
Old 07-17-2016, 06:14:16 PM
geezer88 geezer88 is offline
I love all the ideas about a chump killer sticker. How about a sticker of some sort like the nose art on WWII bombers. Then add dead generator stickers for each contender you destroy with this green beauty.
tom
The Following 2 Users Say Thank You to geezer88 For This Post:
Old 07-20-2016, 10:46:46 PM
Progress on fixing up the 4.0 BFA over the last several days has been slow for 2 reasons:
1) A roof extension on one of my garages started to collapse. I am rebuilding it and got all the wood up and ready to start the shingles. Time permitting I hope to finish by Sunday evening. We are expecting heat near 100 degrees going into Friday (yeah, just my luck, doing a roof). If the "boss" wants to go out which she has already hinted for this weekend everything comes to a halt or she will kill me.
2) I had a hard time removing the BFA's flywheel. My cheap azz Chinese crappy puller tool could not bust it loose, but instead broke. I had to borrow a friend's Snap On puller and it did the trick as seen in the picture below.
Going forward, I plan to pull the timing cover off, replace the front crank seal and the gasket that is between the oil pan base and block. I think it is called the oil pan base gasket. While the timing cover is removed, I plan to check my fly balls for wear of any kind. I got a spare set of balls. Anyway, I plan to replace all the gaskets since oil is/was all over the motor, so I may as well do it now and do it right.
JohnnyC
New Jersey
Old 07-20-2016, 10:59:41 PM
BRae's Avatar
BRae BRae is offline
I usually find my balls in the wife's purse. She lets me use them once in a while.
The Following User Says Thank You to BRae For This Post:
Old 07-20-2016, 11:18:08 PM
Newoldstock Newoldstock is offline
JohnnyC
New Jersey
I made a puller from a piece of plate with nut welded on.
I think it was a 5/8 bolt if I am not mistaken and the plate was screwed tight to the flywheel.
More often than not I find you need to make a puller for a tough job.
You should see my Gib key puller...
The Following User Says Thank You to Newoldstock For This Post:
Kilowatt meter / Receptacle box JohnnyC style JohnnyC Onan Generators 43 08-19-2016 10:17:49 PM
Please help with an Onan purchase decision v10rick Onan Generators 17 11-22-2011 10:00:48 AM
