A Genset Story Onan 6.0 DJB
this thread has 21 replies and has been viewed 2348 times
Old 02-06-2017, 10:34:35 PM
Crankpot Crankpot is offline
Smile A Genset Story Onan 6.0 DJB
I stumbled across this old gen set sitting in a field in Florida somewhat protected by a fiberglass cover. The owner claimed it ran in the past though obviously there were some issues as a few pieces of tin were missing. Also unknown was whether the generator head and regulator made electricity. But for the price of $500 the deal was done, risk accepted and home it went.
The first thing I did was hook up a battery and see if it would crank over, but before, I noticed the very black oil barely touching the tip of the dipstick needed attention. So I bought new filter, changed the oil, primed the fuel system and hit the start switch. It made lots of noise, cranking well, but zero attempt to run.
The next day of troubleshooting indicated there was no fuel flowing to the injectors. This was a new one to me as an experienced diesel mechanic, but as I quickly learned, it's also a pretty common failure mode for this engine. It seems the delicate Ambac injection pump is highly susceptible to the internal plunger sticking from long periods of non use.
Elsewhere in the forum it was discussed a method of freeing up the plunger. I did this and was successful in freeing up my plunger. It reinstalled the pump cranked it up and off it went...sort of.
See the video of it running badly...
https://youtu.be/fCXVhXFBiss
It ran but very poorly. One cylinder cutting in and out, the shaking violently, and it would always give up and quit after less than a minute. I also found both glow plugs were burned out and very difficult and expensive to find.
But some good news came along, for one the generator head was showing output voltage, the oil pressure was building normally, amp meter showed a battery charge.
After another day of struggling with this thing, I realized that injection pump had to be the culprit and ordered another from a guy in eBay. A lot more about this eBay guy later.
The NOS pump arrived in new condition. I paid about $280 for it. I carefully installed it and voila! It started right up and ran perfectly! It seems this gamble was about to pay off.
See the video...
https://youtu.be/CIFTD-wh2S4
The next day I went at it some more, ordered some vibration isolators and miscellaneous tin from Joe... yellowlister, and began making plans to finish and re-paint the gen set. The engine burned clear, ran smoothly started easily. And inspection inside the engine through the injection pump hole showed clean and new looking components. This gen set was installed in a county fire track and seems to have little hours on it.
While beginning to load test the engine it did well, carrying all loads fine, regulating voltage normally. I put it bed with a smile on my face.
The next morning, I started up the little gen set to resume my testing only to find zero electrical output. A couple hours of troubleshooting found one of the four coil pairs in the exciter stator had failed open. I narrowed it down to one coil, found no flaws, so I bypassed the bad coil, reconnected everything and fired it up. Success! The gen set works fine with 7 out 8 exciter coils, I can now find a replacement at my leisure but worst case I can rewind the coil if needed.
As I resumed my load testing the engine quit very abruptly. The total run time in the new pump was about five hours. The thing was completely dead with no indication it would run again.
Some quick trouble shooting showed again no fuel getting to injectors. Injector pump plunger stuck again??? Oh dear.
I removed the pump and found it free and perfectly appearing. But no fuel pumping. The new pump had failed completely in just 5 hours. The eBay auction allowed returns so I contacted the seller and explained this situation. The seller abruptly told me secret "return" conditions were in place and he would not help me until I sent him the pump and sent it out for inspection by a diesel injection shop as I likely ruined it with contamination. Btw..I did not. I was very careful. I am a professional mechanic.
A week later the eBay seller told me that HE, not some diesel shop, had disassembled the pump, found it to be returned in filthy condition (a lie) , and the inside of the pump was contaminated with gasoline (another lie). It went all the way to eBay for disputed resolution and fortunately eBay ruled in my favor giving me a full refund, but wow...what a jerk. His eBay I'd is "rpalesh" (RP Machine Co INC). Govern yourself accordingly.
But it gets weirder. So I buy another NOS surplus pump from another eBay seller. I opened the box and oh boy...a very used corroded nasty pump. Way different from picture of the new one I was supposed to get. Again I complained to the seller and he told me I was mistaken. The pump was Re-manufactured, not new. The pump I got was very old, corroded and for sure... used.
While I was waiting for his response, it installed it and wow! It ran perfectly. If fact it ran so good I kept it and it's still running today, but I did give both these jerks negative feedback for being dishonest.
So here it is. I sanded it down, painted it with Sherwin Williams. Onan blue-green 2 component urethane enamel. It's a nice paint, slightly different from the original color but who knows, maybe the original paint has become a bit darker from aging. It took about half a pint to put three heavy coats on. I made some Onan decals with the little vinyl cutting machine and finished it off with a new muffler. It sits in a couple thick 1.5" square tubes which in turn are bolted to a couple pressure treated 4x4s. The casters are from harbor freight. The whole thing rolls around easily, doesn't shake or vibrate.
The rubber vibration isolators I bought were used but still soft and pliable. Two were badly worn and about 1/4" shorter than the other two. I found some large diameter rubber washers and shimmed the worn isolators up to make them even with the others. It worked perfectly and all mounts have the specified 1/16" airgap and gen set runs smoothly.
See the video....
https://youtu.be/rKY-UWsfBck
I added the little Chinese meter. It shows volts, freq, and hour meter all for $8. It's full of Mobil one 5-40w turbo diesel truck oil.
So hopefully this thing won't give me anymore trouble and provide some years of service. But the fact is these models are at the end of there lives. The parts are hard to find and very expensive even used parts. Enthusiast like myself can fabricate replacement parts to compensate for $400 stop solenoids, finicky injector pumps, and unobtainium, but eventually it will be more trouble than it's worth.
Costs so far...
Purchase. 500
Tin rubbers. 75
Paint. 40
Cables. 50
Pump. 180
Filter. 50
Oil. 22
Glows. 50
Muffler. 30
Total. 997
Pictures...
original condition in field
Detail of rubber foot
the bad coil
Freshly painted awaiting feet
ID:	274187   Click image for larger version
ID:	274188   Click image for larger version
Name:	coil repair.jpg
ID:	274189   Click image for larger version
Name:	just painted.jpg
The Following 15 Users Say Thank You to Crankpot For This Post:
Old 02-07-2017, 12:10:45 AM
JohnnyC JohnnyC is offline
Default Re: A Genset Story Onan 6.0 DJB
EXCELLENT! Beautiful job and an Onan to be proud of. You took the time to detail everything that I could see in the video. Nothing missed.
Too bad you were not posting here while restoring it on a day to day basis with pictures and your input. Many times folks here may see something of interest during the restoration and it may spawn a new thread of a different subject or several pages on the original thread. For example, I just started doing a refurbishment on a 7.5 JB. I found water/moisture under the breather cap and there is a thread currently running regarding the moisture. Lots of great information and thoughts.
Below is a 13 minute youtube video of a 15.0JC that I restored several years ago showing it's original condition and the progress during the restoration. It was my very first Onan and I never heard of or seen an Onan before the one in the video below.
Since then I think I've done 4 other Onans, mostly RV gensets of various kinds. Oh, I did have a 15RJC that I got on CL for pennies, but my intent was to quickly fix it and flip it which I did. There was not restoration.
https://www.youtube.com/watch?v=c8jVNfrCQuI
JohnnyC
New Jersey
Old 02-07-2017, 12:21:34 AM
JohnnyC
New Jersey
Thanks for the kind words. I watched your video of the 15.0 JC. You do GOOOD work! Well done!
The Following User Says Thank You to Crankpot For This Post:
Old 02-07-2017, 12:38:47 AM
Thanks!
Any new projects lined up after you finish up with the scroll tin?
JohnnyC
New Jersey
Old 02-07-2017, 02:59:07 AM
circuitman circuitman is offline
excellent looking machine!i'm, jealous!
The Following User Says Thank You to circuitman For This Post:
Old 02-07-2017, 04:31:47 AM
Billy J Shafer's Avatar
You will not have the cooling door and some shields you see on other units. Because you have the Vac U Flow cooling system.
Old 02-07-2017, 05:59:50 AM
Thanks!
JohnnyC
New Jersey
Oh boy. Endless projects. I'm going to rebuild my cabin MDJA soon. I'll make a vid of it running tomorrow. I converted it from marine to cabin with a Honda radiator and grundfos coolant pump. It's been very reliable and starts easily when bitter cold but needs some tlc.
Old 02-08-2017, 11:03:53 AM
Ray Lynch Ray Lynch is offline
Nice looking set. Good luck with it.
Do you plan on installing a flex connector between muffler and exhaust manifold?
Ray
Old 02-08-2017, 02:25:27 PM
Ray
Yes. Soon.
Old 02-14-2017, 10:54:19 PM
I added a little voltage control to the genset today. The regulator has a different type wiring and I couldn't find a pin out. But the part had a jumper between pins 6 and 7. This is where the potentiometer connects. I used a little 2000 ohm one. It's works great and gives a 30 volt swing. I set the mid point voltage to 120 v using the trimmer in the potted regulator. Sweet! Cost $.30.
Onan Identity Please: (5.0CCK Photos and Story included) Troll Onan Generators 13 02-02-2017 08:20:35 AM
Onan 12.5 JC gets a new home (a story in pictures) b74eqcm Onan Generators 15 11-13-2014 03:24:39 PM
Onan service story Jim Marcozzi Onan Generators 10 06-13-2014 08:37:32 PM
Funny story on new and old onan Kpack Onan Generators 1 01-21-2014 04:58:06 PM
Wards Powerlite 4934 / Onan 10LS Story TomFG Onan Generators 0 02-19-2010 07:37:51 PM
