Quick help with Onan 12.5
this thread has 113 replies and has been viewed 4145 times
Old 03-10-2017, 10:11:53 AM
Handyhiker1 Handyhiker1 is offline
Default Quick help with Onan 12.5
Going to look at an Onan 12.5 4 cyclindee has generator. I assume it is a 12.5 JC. I do not know anything about these units so I am asking advice. What trouble areas to look for? Other then standard stuff, any unusual checks I should make?
Thanks for any info, sorry I have no numbers for this unit.
---------- Post added at 09:11:53 AM ---------- Previous post was at 09:10:35 AM ----------
Let's try this, 4 cylinder gas engine.
Old 03-10-2017, 11:14:23 AM
Default Re: Quick help with onan 12.5
Going out to look at it because???
It wont start? Wont run? Wont make elec.?
I would take the YD service manual #900-0184 and JC service manual #967-0500 along with me.
If it is 12.5 KW and 4 cylinder, my money would be on a J series.
The Following User Says Thank You to Max Thompson For This Post:
Old 03-10-2017, 11:19:15 AM
The price is right.
Old 03-10-2017, 11:35:42 AM
Ray Lynch Ray Lynch is offline
Originally Posted by Handyhiker1 View Post
The price is right.
Phase and voltage meet your needs?
Ray
Old 03-10-2017, 11:38:13 AM
I misunderstood, I thought you were going out to repair it.
Things to check:
Look in the control box for rodent damage or hack jobs on the wiring.
Be sure the engine will turn over and is not locked up.
Is the starter, carb and all cooling tins included.
This is a very short list. If the price is right (scrap price) you can always part it out if it doesn't pan out.
Just for fun, take some pictures and get the data tag info even if you do not buy it.
Old 03-10-2017, 11:58:00 AM
Ray
Don't know. This is a total unknowns unit. I will look though.
Old 03-10-2017, 03:52:13 PM
I bought the generator. Here is a pick of the tag. Getting it delivered tomorrow morning.
The Following User Says Thank You to Handyhiker1 For This Post:
Old 03-10-2017, 04:09:57 PM
BigBlockChev's Avatar
You won't be sorry. Most frequent issue with J series YD genend sets is the voltage regulator which can be replaced cheaply or with a more expensive regulator. If it runs and generates you are golden. Cheers Dan
It's always something simple.
If some is good and more is better then too much is just enough
The Following User Says Thank You to BigBlockChev For This Post:
Old 03-10-2017, 06:12:02 PM
Well it does not run so I don't know about producing power. It is complete from what I saw and I was able to spin the engine by hand. There is a mouse nest in the control box but I don't know how much damage they did.
I will do some checks on it tomorrow when it gets delivered.
I am sure I will have questions since I have never even seen this model in person let alone worked on one. I will grab some pictures and post them when I get it.
Old 03-10-2017, 07:35:54 PM
I assumed you had bought it when I saw the listing had been deleted.
In my "opinion" (for what it is worth) the JC sets are very easy to work on because of their size and design. They are large enough that components are not jammed into a small inaccessible place, yet small enough to move around on a cart by yourself. The controls are very simple, and as mentioned all the high $ OEM electrical parts can be replaced with aftermarket parts very reasonably.
The Following 3 Users Say Thank You to Max Thompson For This Post:
Onan Quick CCK remote prime question. Flintstone Onan Generators 41 02-19-2015 05:21:28 AM
Onan JC quick connect natural gas hose vlocci Onan Generators 9 09-15-2014 03:27:03 PM
Quick question on Onan DJB rcowboy Onan Generators 7 02-10-2013 04:38:03 PM
Found a good quick way to strip paint from an Onan CCK carburetor Motorhead Onan Generators 14 02-06-2013 03:21:37 AM
Need quick help!! Kman Oil Field Engines 4 02-03-2008 07:21:14 PM
