Quick help with Onan 12.5
this thread has 113 replies and has been viewed 4152 times
Old 03-10-2017, 08:04:08 PM
Handyhiker1 Handyhiker1 is offline
Default Re: Quick help with onan 12.5
I am excited to get this, it is the largest both size and output that I have ever had. I know it won't be fuel efficient but it will be neat to play with. I really don't need one this big, just couldn't pass it up. I may get it running and working and then look to sell it. Have to wait and see.
Old 03-10-2017, 09:15:47 PM
Ray Lynch Ray Lynch is offline
Originally Posted by Handyhiker1 View Post
I am excited to get this, it will be neat to play with. .
Yes it will...have fun.
Ray
The Following User Says Thank You to Ray Lynch For This Post:
Old 03-10-2017, 10:34:44 PM
JohnnyC JohnnyC is offline
Congrats on your JC purchase. The mouse is almost a guaranteed non-desirable option that comes with the J series Onans although Onan does not have an option code for them.
JohnnyC
New Jersey
Old 03-10-2017, 11:04:33 PM
Jim McIntyre's Avatar
^ Yep the cheese-covered control wiring and rodent revolving door in the control box were actually standard fittments - not an option at all...
Old 03-11-2017, 03:00:43 AM
This rare photo of an Onan Design Engineer hard at work on the computer explains a lot of the rodent related problems with these sets.
Ray
http://4.bp.blogspot.com/-WWN2jvTnHr...tures+(13).jpg
The Following 4 Users Say Thank You to Ray Lynch For This Post:
Old 03-11-2017, 07:14:52 AM
Here is the picture of what the seller posted. It actually looked a little better in person, not a lot but a little. :-)
Old 03-11-2017, 07:53:16 AM
Originally Posted by Max Thompson View Post
Going out to look at it because???
It wont start? Wont run? Wont make elec.?
I would take the YD service manual #900-0184 and JC service manual #967-0500 along with me.
If it is 12.5 KW and 4 cylinder, my money would be on a J series.
Are these the only 2 manuals I will need for this unit?
Another question, I noticed that some of these units seem to be forced air cooled and some are vacuflo cooled, any real difference? I would assume this had to do with the way it was mounted. I was told this one was in a motor Home so that is why the vacuflo system.
Old 03-11-2017, 11:43:58 AM
Those 2 manuals will answer most of your questions. The service manual covers the engine and most of the control system. The YD manual covers the generator end.
The vacu-flow sets allow the cooling air to be "directed / ducted" much more easily than the pressure cooled units.
I am finding the vacu-flow set much more covenant to "work on", because the side of the engine with the distributor, carb and governor is open and accessible while the engine is running. On the pressure cooled sets, these items are all behind the cooling tin that must be in place while the engine is running which requires removing and reinstalling the tin with each "adjustment" if the engine is going to be run for more than just a few minutes.
The exhaust side is a little more difficult to access, but not much to do over there.
The Following 2 Users Say Thank You to Max Thompson For This Post:
Old 03-11-2017, 02:41:50 PM
Oh my!! I just discovered something bout the generator, it is a factory duel fuel!! It has the gaseous directions and intake maniold as well as gas. I didn't even realize it at first.
Old 03-11-2017, 02:43:37 PM
A few pictures.
ID:	277113   Click image for larger version
Onan Quick CCK remote prime question. Flintstone Onan Generators 41 02-19-2015 05:21:28 AM
Onan JC quick connect natural gas hose vlocci Onan Generators 9 09-15-2014 03:27:03 PM
Quick question on Onan DJB rcowboy Onan Generators 7 02-10-2013 04:38:03 PM
Found a good quick way to strip paint from an Onan CCK carburetor Motorhead Onan Generators 14 02-06-2013 03:21:37 AM
Need quick help!! Kman Oil Field Engines 4 02-03-2008 07:21:14 PM
