Quick help with Onan 12.5
this thread has 113 replies and has been viewed 4148 times
Old 03-11-2017, 02:46:43 PM
Handyhiker1 Handyhiker1 is offline
Default Re: Quick help with onan 12.5
A few more. I have $175 for it and got it delivered. I think I did okay. :-)
ID:	277115   Click image for larger version
ID:	277116   Click image for larger version
ID:	277117   Click image for larger version
The Following 2 Users Say Thank You to Handyhiker1 For This Post:
Old 03-11-2017, 03:06:53 PM
You paid $175.00 and it was delivered???? Lucky Bugger you are!!!!!
Nice mouse condo! It will be a great set!
The Following 3 Users Say Thank You to nothingbutdarts For This Post:
  #23
Old 03-11-2017, 05:26:16 PM
Jim Marcozzi Jim Marcozzi is offline
A few little squirts of expandable fire foam will fix the JC mouse problem.
Mice love to eat the regular expandable foam, but for some reason, they don;t like the orange fire rated foam. And as a bonus, the fire foam stays a little pliable once set up.
Old 03-11-2017, 05:37:24 PM
Motorhead's Avatar
Looks like someones car seat will be short a little padding! Nice score. Can't go wrong for that price unless the WHOLE set is a "Boat Anchor".
The Control panel
and gauges of my
7.5JB
Old 03-11-2017, 06:59:24 PM
Kevin K Kevin K is offline
Thanks! I didn't know fire rated expandable foam existed. It's a bit pricey, about double the cost of standard foam, but if it acts as a mouse barrier, well worth the cost.
Old 03-12-2017, 08:23:42 AM
Can someone please tell me the weight of this unit? I looked in the manuals but didn't see it listed.
Old 03-12-2017, 08:43:33 AM
The sales literature lists an approximate weight of 655 Lbs for a 12.5JC.
  #28
Old 03-12-2017, 04:11:52 PM
I have been through this from one end to the other. Looks good. Pulled all the plugs and cleaned them, cleaned and checked the points, straightened out some bent shrouds and cleaned out the mouse nest. Working on the carb now. I might get a chance to try to fire it up yet today. :-)
The Following User Says Thank You to Handyhiker1 For This Post:
  #29
Old 03-12-2017, 06:00:26 PM
Talking Re: Quick help with onan 12.5
It runs!! I still have a few problems to work out but it fires an runs. Don't know about producing power yet because I couldn't let it run long enough to get my meter.
First problem, the oil filter housing is dented and leaks oil when the engine built pressure. This is a canister filter, are these housings easy to find?
Second problem, one of the throttle links is broken. I know I can get this locally.
Third problem, the fuel pump would not catch prime. I may need to pressure feed the fuel with an electrical pump till it gets the diaphragm wet.
There is no exhaust so it was loud but all 4 cylinders did fire.
Other then these issues, I am so happy with the progress I made today and with the outcome of it all.
As soon as I can find the filter housing I will get a new filter and change the oil now that I know it runs. The oil really doesn't look bad just slightly dark. Must have been changed not too many running hours ago. Oh, I need an air filter too.
I took a picture of some kind of coil in the power conection box. It has two small wires run to it, my guess is 12v. Any idea what this is?
Old 03-12-2017, 06:18:05 PM
Onan Dan's Avatar
Onan Dan Onan Dan is offline
That is a current transformer to show voltage or amperage
The Following 2 Users Say Thank You to Onan Dan For This Post:
Onan Quick CCK remote prime question. Flintstone Onan Generators 41 02-19-2015 05:21:28 AM
Onan JC quick connect natural gas hose vlocci Onan Generators 9 09-15-2014 03:27:03 PM
Quick question on Onan DJB rcowboy Onan Generators 7 02-10-2013 04:38:03 PM
Found a good quick way to strip paint from an Onan CCK carburetor Motorhead Onan Generators 14 02-06-2013 03:21:37 AM
Need quick help!! Kman Oil Field Engines 4 02-03-2008 07:21:14 PM
