Quick help with Onan 12.5
this thread has 113 replies and has been viewed 3916 times
Old 03-12-2017, 06:20:02 PM
Default Re: Quick help with onan 12.5
The coil in the box is the CT (current transformer) coil for your amp meter.
Glad to hear it runs, that is always a relief to know you have not bought a boat anchor.
Be sure the diaphragm on the fuel pump is not leaking into the crank case.
No idea on the filter canister, I have not had one that did not have a spin on filter yet.
The Following 3 Users Say Thank You to Max Thompson For This Post:
Old 03-12-2017, 06:24:46 PM
Dale Russell Dale Russell is offline
Maybe you can find an adapter for a Spin on filter. Just a thought!
The Following User Says Thank You to Dale Russell For This Post:
  #33
Old 03-12-2017, 06:37:55 PM
nothingbutdarts nothingbutdarts is online now
Default Re: Quick help with Onan 12.5
post what you are looking for in the parting out thread here:
https://www.smokstak.com/forum/showthread.php?t=99191
The Following 2 Users Say Thank You to nothingbutdarts For This Post:
  #34
Old 03-12-2017, 07:35:59 PM
Handyhiker1 Handyhiker1 is offline
I don't think the current transformer is factory onan. The wires to it run through a hole tears the back and have was been cut. Must have been for a remote read meter.
Old 03-12-2017, 10:33:55 PM
BigBlockChev's Avatar
I would think that you could convert the oil filter to spin on fairly easily. The cartridge oil filter must have been a less common option as I have never seen one. Put up some pics so we can see what the base looks like. I think you won on this set. Cheers Dan
It's always something simple.
If some is good and more is better then too much is just enough
The Following User Says Thank You to BigBlockChev For This Post:
  #36
Old 03-12-2017, 11:46:56 PM
Vanman Vanman is offline
Just make sure that the CT is either connected to an ammeter or shorted before you apply a load to the conductor that passes through it.
Old 03-13-2017, 05:06:23 AM
I am actually thinking about just removing it. Since I don't know what kind of gauge went to it or even what brand, I don't think I need it taking up space and adding extra weight.
Old 03-13-2017, 12:26:00 PM
Agreed that that is the best course of action if it will not be used for anything. Most ammeters are 5 amp to full scale, and the CT should be labeled as to its turns ratio. For future reference, or if you decided to sell it.
Old 03-13-2017, 07:31:33 PM
If you want it, it is yours. Pm me and I will get it to you.
This uses the small oval paper or foam filter I guess. I looked in the manual but can't find a part number. Is there a cross for the factory air filter?
Thanks.
Old 03-14-2017, 05:30:22 AM
I found the parts manual and figured out what air filter I need. This will help a lot.
Onan Quick CCK remote prime question. Flintstone Onan Generators 41 02-19-2015 05:21:28 AM
Onan JC quick connect natural gas hose vlocci Onan Generators 9 09-15-2014 03:27:03 PM
Quick question on Onan DJB rcowboy Onan Generators 7 02-10-2013 04:38:03 PM
Found a good quick way to strip paint from an Onan CCK carburetor Motorhead Onan Generators 14 02-06-2013 03:21:37 AM
Need quick help!! Kman Oil Field Engines 4 02-03-2008 07:21:14 PM
