Quick help with Onan 12.5
this thread has 113 replies and has been viewed 4283 times
Old 03-18-2017, 08:00:25 PM
Handyhiker1 Handyhiker1 is offline
Default Re: Quick help with Onan 12.5
Here are a few pics of the exhaust pipe and muffler. There are 2 hangers welded to the back of the muffler and bolted to the engine. This thing is solid as a rock.
ID:	277853   Click image for larger version
ID:	277854   Click image for larger version
Old 03-18-2017, 08:40:32 PM
Motorhead's Avatar
Nice job on the muffler. Man.... That control box has seen its share of MOUSE PEE!!!
The Control panel
and gauges of my
7.5JB
  #53
Old 03-18-2017, 08:49:23 PM
I am figuring that is what caused the part to fail. Two of the brass screw heads actually broke apart when I tried to remove them. Never had that happen before.
I have looked in the manuals and on e bay but can't seem to find a part number for the relay that I need. Anyone know the number or where I can get one?
Old 03-18-2017, 09:58:27 PM
That is the K-12 ignition / start disconnect relay and the problem you have is very common. A new OEM relay will probably cost $100 or more if you can find one. I have cleaned the contacts on a few and gotten them to work, yours looks to be pretty far gone.
I have been replacing them with plug in relays and bases from Allied Electronics for about $20 and a little time rewiring. https://www.smokstak.com/forum/showt...15080&page=145 see post 2886. I have posted a crude wiring diagram somewhere.
Before you remove your relay, draw a diagram of the relay and number each terminal. Then tag all wires with corresponding numbers as you take them off. This can save a lot of tracing later.
https://www.smokstak.com/forum/album...pictureid=9460
I put a copy of the diagram in am album so I do not have to look for it again. NOTE; the coil on that relay is 6-V. I do have a few used ones left from conversions, but I would go with the new style relays.
The allied part numbers are also there now, the list was a PDF I uploaded to the album instead of a picture so it is a little hard to read.
The Following User Says Thank You to Max Thompson For This Post:
  #55
Old 03-19-2017, 09:21:27 AM
I found a guy locally that has a few used ones. If the price is cheap enough, I may try one and see how it goes. If not I will definitely be doing the conversion to the new style.
Thanks for the info!!
Old 03-19-2017, 09:27:34 AM
JohnnyC JohnnyC is offline
Whoever did the muffler / exhaust job did an excellent job as seen in your previous pictures.
JohnnyC
New Jersey
  #57
Old 03-19-2017, 11:42:57 AM
The local guy wants $25 for the factory used part. I have seen a photo of it and the box it is in, looks really clean. What do you think?
Old 03-19-2017, 11:44:26 AM
JohnnyC
New Jersey
This is a buddy of mine. He owns the local exhaust shop.
The Following User Says Thank You to Handyhiker1 For This Post:
  #59
Old 03-19-2017, 12:08:45 PM
Hand him a $20.00 and walk away with it!
The Following User Says Thank You to nothingbutdarts For This Post:
  #60
Old 03-19-2017, 01:33:12 PM
Kind of what I was thinking too. Thanks.
He won't drop the $5, going to tell him to keep it and do the new chanc over.
Onan Quick CCK remote prime question. Flintstone Onan Generators 41 02-19-2015 05:21:28 AM
Onan JC quick connect natural gas hose vlocci Onan Generators 9 09-15-2014 03:27:03 PM
Quick question on Onan DJB rcowboy Onan Generators 7 02-10-2013 04:38:03 PM
Found a good quick way to strip paint from an Onan CCK carburetor Motorhead Onan Generators 14 02-06-2013 03:21:37 AM
Need quick help!! Kman Oil Field Engines 4 02-03-2008 07:21:14 PM
